HxCFloppyEmulator v2.0.18.4 missing Amiga file system type
Rylos
Post by Rylos »
Was this taken out on purpose? if so what would I select in its place?
Re: HxCFloppyEmulator v2.0.18.4 missing Amiga file system ty
Rylos wrote:Was this taken out on purpose? if so what would I select in its place?
2 possibilities :
- ADFOpus with HFE support :
https://hxc2001.com/download/floppy_driv ... us_HxC.zip
OR
- create a "myfloppy.amigados" folder the pc.
- drag & drop it on the hxc application
- export the image (hfe format).
Rylos
Post by Rylos »
Ok after creating the disk, myfloppy.amigados, ADF Opus reads and displays the disk correctly but when I try to View it in HxCFloppyEmulator using the Disk Browser I get the following error.
"DOS Floppy Disk File Browser" is the name of this window.
You are trying to browse Amiga disks with it...
Rylos
Post by Rylos »
MS DOS, Amiga DOS... Man! :)
Thanks, I guess ADF Opus it is.
Rylos
Post by Rylos »
Ok, I've got to ask.
So you are saying that this window is only for MS DOS file systems Right?
But, if you list the file systems type there are 4 types of Atari disks available to choose. Thus my original question about the missing Amiga file system.
I thought that this window was file system dependent which would have been really cool.
Atari ST = DOS file system.
If someone want to add the AmigaDos support all the sources are there :
http://sourceforge.net/p/hxcfloppyemu/c ... yEmulator/
ADFlib is already into the hxc library so this should not be too hard.
Rylos
Post by Rylos »
The Amigados support was in version 2.0.16.0, see attached. It just didn't make it to the new version. Though it gives the same red DOS error as above when I try to use it but I figured it was something I was doing wrong. Maybe it didn't work so it was removed? Anyway, ADF Opus seems to work so I'll use that. Thanks, and sorry to be a pain. Software QC is what I do for a living.
The AmigaDOS FS support was planned but never got the time to finnish it. So i prefer to remove the entry for the moment...
Rylos
Post by Rylos »
Thanks Jeff
Rylos
Post by Rylos »
03 January 2014: HxCFloppyEmulator 2.0.20.1
Disk Browser : AmigaDOS disk support added ! Amiga Files can be read/write/deleted with the Disk Browser !
Thank You!!!
Jeff! Jeff! Jeff! :)
tophe38
Post by tophe38 »
Is support for AmigaDOS completed ?
When using image generate on real Amiga, or convert it to ADF and using WinUAE, It's mounted as NDOS ...
Regards,
Christophe
tophe38 wrote:Hi,
Regards,
Christophe
issue solved in the beta version.
