will not read sd card with TT030
diamondspringwater
Post by diamondspringwater »
Just got the Hxc sd, put it in my TT everything seems to work the light comes on when I click on drive A, then is says can not read disk. I formatted the sd card and coppied the Atari files to it from the Hxc website. I am using a 2 gb sd sandisk.
Any Ideas would be helpfull thank you.
Re: will not read sd card with TT030
diamondspringwater wrote:Just got the Hxc sd, put it in my TT everything seems to work the light comes on when I click on drive A, then is says can not read disk. I formatted the sd card and coppied the Atari files to it from the Hxc website. I am using a 2 gb sd sandisk.
Which files ?
diamondspringwater
The QuickInstall_floppydiskimages.zip files I downloaded and opened then I opened the SDHxCFE,Atari ST.Zip folder and coppied everything to the sd card.
Which HxC ? The Slim one ?
If yes please activate the AUTOBOOT mode into the cfg file. (file attached).
HXCSDFE.zip
(212 Bytes) Downloaded 876 times
diamondspringwater
Okay that got it to boot to the Hxc manager, thank you. But it always reboots to the manager program no matter what program is set to disk 1 and 2. I have tried f-10 and f-7 any idea what I am doing wrong.
Thank you
diamondspringwater
I put the quick start images on the sd card and it loads the blank disk images and tries to load dark side of the spoon. I must not be converting the images corectly.
diamondspringwater wrote:I put the quick start images on the sd card and it loads the blank disk images and tries to load dark side of the spoon. I must not be converting the images corectly.
Have you this ? :
https://hxc2001.com/download/floppy_driv ... r_soft.zip
