Bugs for converting 1DD type D88 images .
kitahei88
Post by kitahei88 »
My friend use HxC on PC-6601SR.
The drive on PC-6601SR is 1DD type .
So he make D88 images to HFE images using HxC Floppy Emulator Software.
But the HFE image missed the last track.
D88 images for 1DD disks has Track 0 to 79 but the datas are only in surface 0, and all of tracks in surface 1 are unformatted.
With such images , HxC Software says only Track 0 to 78 , missed Track 79.
So I attached some datas in the D88 images on Track 79 surfce 1 , and send it to HxC software, it says Track 0 to 79.
I think that HxC software cannot recognize last track if the D88 images has the unformatted track in the last.
I attached two files , Util.d88 is original 1DD type D88 image.
And Util_fix.d88 is modified images .
d88.rar
Regards.
Re: Bugs for converting 1DD type D88 images .
kitahei88
Post by kitahei88 »
Thank you,Jeff.
the beta software works fine.
And attached data has copyright problem , so I delete it.
