Setting Up Usb floppy emulator on a pc-9821
xybots
Post by xybots »
Hi everyone
I have both the usb version of the the floppy emulator and a sd card version which i made when it first was released, i want to connect either board to my nec pc-9821 xa200 computer.
Can any one help me set up the usb board to use with my pc98 what setting etc i need and does any one know what setting i need if i want to use the sd card floppy drive board i made if it can work with it.
Thanks for your help
Brian
Re: Setting Up Usb floppy emulator on a pc-9821
Which file images have you?
xybots
Post by xybots »
Hi Jeff
I have D88, FDI, FDD images if all the file images cannot be used can i convert them ?
And can i use the sd card beta pcb which i made when you first released it and how do i set the jumpers for the drives
And can i also use the usb floppy emulator rev c will i need to use 2 usb floppy boards for 2 drives ?
thanks
Brian
xybots
Post by xybots »
Hi Guys
I am still having trouble trying to boot up the usb floppy drive to my pc-9821 any help would be grateful, as the hard drive failed and i need to boot up with a disk in the drive but the floppy drive is not working so trying to set up the usb floppy version or would the sd pcb beta board work ?
thanks for your help
I still don't have your file images...
xybots
Post by xybots »
Hi Jeff
sorry mate how do i send you the image files email ?
just another question the sd floppy emulator beta what way do the jumpers for the floppy drive go
thanks
Brian
SkyeWelse
Post by SkyeWelse »
Hi Xybots,
You and I have spoken before on another forum, but for others benefit as well, I posted a possible related solution in this thread here.
Take care!
-Thomas
