Jeff wrote:Have you a working floppy disk for this machine ?
If yes just try to copy all files present on this floppy to the virtual floppy image.
Or use the floppy disk dump feature to make an image from this floppy.
I have made the virtual floppies on the SD card, the Morbidelli reads them fine.
I think my issue was the machine needs the .PGM file copied to the machines Ram Drive to allow it to work correctly.
The machine needs to look at other files like the tooling setup file etc. to operate, and we really only need to move the file from a PC to the SD then into the ram drive on the Morbidelli.
I'm helping a friend with his machine and I won't be back there until Jan 17th. I will update you after my next visit.
Regards
Tim R
