HxCManager V3 don't start
DerSchatten
Post by DerSchatten »
I have a Problem with the HxC Manger V3 on my Amstrad CPC464.
When i start it with run"hxc, he shows me the error:
Syntax error in 10
10 ON BREAK CONT
I use the Firmware 1.8.2.40
The older Version (V2.5) works fine.
DrLivingstone
Re: HxCManager V3 don't start
Post by DrLivingstone »
marioweezer
Post by marioweezer »
Sorry to drag this thread back up but did you ever manage to get this working on your CPC 464? I'm having the same error with V3 - the previous V2.5 works fine though.
I'm wondering if V3 is actually compatible with a CPC 464 with only 64kb.
redbug
Post by redbug »
Same problem for me
Hang on "10 ON BREAK CONT"...
Fernecho
Post by Fernecho »
the same probleme for me, Amstrad CPC464, manager v3, the older 2.5 version works fine
TFM
Post by TFM »
Similar problem here. Does not work.
TFM wrote:Similar problem here. Does not work.
Unfortunately i never got the sources of the V3 HxCManager for CPC.
You have to contact Norecess.
I got a feedback from Norecess :
OK je connais le probleme. Les 6128 ont BASIC 1.1, alors que les 464 ont BASIC 1.0. Or, le HxC V3 utilise une astuce pour le lancement qui porte sur l'utilisation du BASIC. L'encodage des "opcodes" BASIC est different d'une version a l'autre.
J'etais parti du principe que des utilisateurs de 464 qui avaient un drive externe (dur a trouver) modifié par un HxC dedans serait tres rares . Et que pouvait toujours utiliser la version 2.5 du HxC.
Je regarderais ca ce soir ou demain, a priori on pourrait s'en sortir avec un "patch" de quelques octets. Je croyais t'avoir deja fourni les sources, je vais en profiter pour redonner ca.
A+
So a patch is on the way ! :D
The V3.1 is available. This version fix the 464 support issue :
https://hxc2001.com/download/floppy_driv ... anager.zip
DrLivingstone
Jeff wrote:The V3.1 is available. This version fix the 464 support issue :
The link is not correct. :(
The version of HXC in CPC version is 2.5 of 17/10/2011.
On the website of Noreccess.cpcscene http://norecess.cpcscene.net/hxc-floppy ... nager.html is the same.
DrLivingstone wrote: The link is not correct. :(
This is the right one
DrLivingstone
TFM
Post by TFM »
Thanks! Great! :D :D :D
