TCP/IP Network & USB Floppy Emulator !
We are studying the subject :wink:. A Future Design ? :roll:
The wireless version is already there :D
EDIT : Update -> control & upload through a simple web browser :D
https://hxc2001.com/img/hxcfe/USB_HxC_Fl ... Pi_001.jpg
glenns
Re: TCP/IP Network & USB Floppy Emulator !
Post by glenns »
Great work , another project I can try on my raspberry Pi, I'll have to get a USB HxC asap :)
We could even run 3/4 HxC from one rPi!
Work in progress !
krusty
Post by krusty »
I am wandering if I will replace my SD hxc by the usb version (plugged on my Linux machine or a raspberripi). But before
- are there any progress in this web ui ? or any server application ?
- if yes, is the code on the repository ? Otherwise, I guess anybody can reproduce it by looking at the function usbload in https://sourceforge.net/p/hxcfloppyemu/ ... cfe.c#l427
- host machine cannot write on the image. Is it a limitation for ever, or will it change one day ?
thanks
Henry89it
Post by Henry89it »
Is there anywhere the TCP/IP code?
It will be great if you can share it!
Thank you
Henry89it wrote: Wed Jul 31, 2019 4:57 pm Is there anywhere the TCP/IP code?
Thank you
You mean the webpage ? All the others stuff is just the command line hxc software working in background.
Henry89it
Post by Henry89it »
Yes I mean the webpage.
Is the web server already active on Raspberry?
Henry89it wrote: Wed Jul 31, 2019 6:01 pm Yes I mean the webpage.
On the Raspbian ? i am not sure but you can active/install it easily.
attached the www of the hxc rpi poc project.
www_hxcrpi_poc.tar.gz
(36.29 KiB) Downloaded 3734 times
Sorry for the lame cgi codes :wink:
