amiga 1000 news
magoburicchio
amiga 1000 news
Post by magoburicchio »
hi guys
last news about amiga 1000 was about 2011
i bought today an amiga 1000
my first question is
-- can hxc run kickstart at the start? i can select between kickstart? (like amiga 1200 kickstart?)
-- can i swap from one disk to another?!? example at the start i select load kickstart 1.3 after monkeyisland d1 --- d2 wher request ecc?
---which version can i buy ? is also an external version to put outside without break anything?
thks a lot
Lorenzo
Re: amiga 1000 news
magoburicchio wrote:hi guys
thks a lot
Lorenzo
already responsed by email to you...
<<All sd card versions have the same function.
>example if i use kickstart and 3 disk game it recognize first the
>kickstart and after disk 1 - 2 -3? i can swap beetween them with
>buttons? is all inside ? (example i need extra software?)
You can use them with the file selector or only with the lcd & buttons.
>i can put inside the sd kickstart and rom and loading them ?
yes
> i need soldering?
no
>is supported also multidisk?
yes
>the screen is different from the original? i've a menu where select first the kickstart and after de game?
the emulator don't care : kickstart is a floppy disk, games are floppy disk too..
http://lotharek.pl/product.php?pid=91
http://lotharek.pl/product.php?pid=42
