Floppydrive emulator and TRS80
Hans
Post by Hans »
Is anybody successfull with using image files on a TRS80.
I have a TRS80 Model4P and I want to use some old image files on this computer.
In this case:
SEADRAGON.DSK
COPYCAT.DSK
SU4.DSK
DANCING DEAMON.DSK
Somebody succeeded with these image files ?
Any tips for this type of files would be nice.
Re: Floppydrive emulator and TRS80
what it is ? JV1, JV3 or DMK files ?
if this is JV1 files, change the file extension to .JV1
Hans
Post by Hans »
Most of them are JV1 files.
Changing the extension doesn't help.
I still get a no disk error.
The trackcounter on the emulator goes up to 229.
These are double boot disk (model 1 and other)
This is some kind of protection.
The software emulators for TRS80 can boot these disk with no problems.
Do I need a special configuration for the HxC emulator ?
Send me the files , i will check this.
Frank
Post by Frank »
Hello Jeff,
i have difficulties with some TRS-80 files.
One of these is http://www.classiccmp.org/cpmarchives/t ... 8-0009.zip
When i try loading this, "Load error! Read file error!" appears.
Frank
Frank wrote:Hello Jeff,
Frank
a dmk with 10 tracks....
So retry with this dll :
https://hxc2001.com/floppy_drive_emulat ... bhxcfe.zip
(replace the old one.)
Frank
Post by Frank »
Hello Jeff,
thanks a lot.
This works with the images fine.
Is this fix included in following versions?
Frank
thanks a lot.
Frank
yes sure. but do you have other non-working images ?
Frank
Post by Frank »
Hello Jeff,
here is one more, that is not loadable.
Frank
Frank
lol, a 6 tracks image
Updated :
Frank
Post by Frank »
Hello Jeff,
also this works now.
What about 5 track images? :lol:
Frank
Frank
I have understand. Now i just check that the track is != from 0 into the sanity check/format detection... :wink:
Other non working image ?
Frank
Post by Frank »
Thanks Jeff,
at the moment i have no non-working files.
Frank
Audronic
Post by Audronic »
@ Jeff
Hi Jeff
I am using a Trs-80 Model 1 using SINGLE DENSITY Single sided 35/40 Track disk Images.
I can convert them to work on the TRS-80 which works well.
If i want to use the Disk Browser in the HxCFloppyEmulator v2,0,20,0.
It always shows " Some errors-------" in a red stripe.
as I cannot choose a SINGLE DENSITY file type,
Is there a patch that can be applied or a SINGLE DENSITY Type be included in the dropdown menu Please.
Ray
If it ain't Broke then PLEASE DONT fix it.
Procrastinators Unite !
The Disk browser is to browser DOS/FAT or AmigaDOS floppy.
What are you trying to do?
