Request for HxC_SD_Bootloader_V1_0TOV1_1.upd
DoJu91
Post by DoJu91 »
Hi everyone,
I've got a Rev B of the SD HxC FD emulator, my firmware is 1.1.1.0 when it boots.
I've read the docs and there is mention of the .upd I need in the subject header, as per:
https://hxc2001.com/floppy/forum/viewtopic.php?f=2&t=842
Can someone please provide this .upd so I can upgrade my firmware to a new revision?
Once I've upgraded, I will perform the following along with copying a few HFE's
copy/replace HXCSDFE.CFG to your sdcard.
copy AUTOBOOT.HFE to your sdcard.
(Note: it is recommended to copy these 2 files right after having formatted the SDCard)
If your emulator is set as DF0 you must use AUTOBOOT.HFE present in the Emulator_as_DF0 folder.
If your emulator is set as DF1 you must use AUTOBOOT.HFE present in the Emulator_as_DF1 folder.
Re: Request for HxC_SD_Bootloader_V1_0TOV1_1.upd
In your email box !
DoJu91
Post by DoJu91 »
Jeff wrote:In your email box !
Thanks for the quick reply. I've tried to apply the update but I note:
Red LED light permanently ON state
Orange LED light permanently ON state
Then I get 4 blinks .... 4 blinks .... 4 blinks
is in the root of the SD (I formatted a few hours ago with SD formatter, FAT32, 2Gb, Fujitsu SD card)
format it with windows. If still doesn't work, try another sd.
DoJu91
Post by DoJu91 »
Jeff wrote:format it with windows. If still doesn't work, try another sd.
I've tried a Kodak 64Mb SD, SanDisk 2GB SD, FujiFILM 2Gb SD
All same result ... three LED all lit up, none blinking.
I'm in Australia, the Amiga 2000 Floppy cable can only be inserted one way, with the red wire on pin 1 side.
There is a tiny twist in the cable.
FDD power cable is yellow, blue, blue, red and will only connect in that direction.
So I hold down left / right, power on the Amiga 2000, hold for 1-2 seconds, still on version 1.1.1.0
Are you sure that you entered into flash mode ? the lcd should not be initialized.
DoJu91
Post by DoJu91 »
Jeff wrote:Are you sure that you entered into flash mode ? the lcd should not be initialized.
How do you mean "initialized"?
When I hold down left/right then power on, then hold for 1-2 seconds, I get no letters on the LCD screen, only 8 or so square blocks indefinately.
Would be cool if it would say "firmware updating ... "
I've read on another thread that a Kingston SD card worked for another HxC user, so I'll buy one and give it a test...
BTW where and when did you get this old Rev B emulator ?
DoJu91
Post by DoJu91 »
Jeff wrote:BTW where and when did you get this old Rev B emulator ?
ebay as new in mid-2011 from lotharek's portal (only place to get them).
I bought another SDHC card today brand new, this one's a SONY 8GB, FAT32, copied the v1_0tov1.1.upd and same result:
Red LED light hard-on
Yellow LED light hard-on
4 flashes (can't find the .upd) file which is weird.
The Amiga FDD cable can only connect on the motherboard one-way as there is a pin filled in on the cable so you can't swap it.
DoJu91
Post by DoJu91 »
Im finally making some progress...
The FDD cable was replaced with a spare which allow me to reverse the cable that connects to the HxC
Now i have the power LED light on, floppy access LED Off, SDcard acces LED Off
Put the SDCard in .... returns "reading FAT..."
mid 2011 ? a Rev B ? i am quite surprised.
Rev C come summer - late 2010.
DoJu91 wrote: Im finally making some progress...
This is not a progress : the bootloader update still not done.
Maybe you should ask to Lotharek a bootloader update services for your device.
DoJu91
Post by DoJu91 »
Shall do, as all I'm getting now is flashing Floppy Access LED and SDCard access LED
Its a Rev B 050310 SDCard HxC Floppy Emulator card.
DoJu91
Post by DoJu91 »
Thanks Jeff, I've sent an email to Lotharek and provided him with the information:
Dear Lotharek,
Jeff has requested I talk to you to see if I can get a a bootloader update services for my device, as per:
https://hxc2001.com/floppy/forum/viewtopi ... 8795#p8795
I have a Rev B 050310 HxC2001 SDCard FDD emulator
I'm running firmware v1.1.1.0
I can't seem to update the firmware
I've tried 4 different SDHC cards none have worked
I'm using it on an Amiga 2000
Hope you can be of assistance
Steve
Hobart, Tasmania, Australia
One question by curiosity : did you used the device in the past or was it in its package since 3 years ?
