Emulator II+ HxC won't load floppy images (INSERT PERF DISK)
n82558
Post by n82558 »
Hi everyone,
I have an Emulator II that I just finished repairing and I installed an HxC rev
F. I followed all the directions but the EMU just won't load my .hfe files. I
have a few different images on the SD card and none of them work. I have some
that are only firmware files, one that I converted myself from an emuiifd file
with an OS overlay in the hxc software, and one that I downloaded from a forum
where someone converted a file to help another user solve a problem that sounds
like the one I'm having. If I have the HxC as the only drive in the EMU it just
says insert diskette, and if I boot on a floppy and then try to load from the
Hxc I get a message that says "INSERT PERF DISK AND PRESS ENTER'. I've tried
different jumper settings and everything else and I still don't have any luck.
Anyone have advice for me? Do I have a defective HxC?
Re: Emulator II+ HxC won't load floppy images (INSERT PERF D
Try the Emu II images in this zip :
What do you see on the HxC LCD ? Can you take a picture of the lcd hxc ?
n82558
Post by n82558 »
Hi Jeff, thanks for your quick reply. I used the images in the zip file you sent me, still no luck. The emu screen just says 'insert diskette'. Here's what the hxc looks like:
Have you checked the floppy cable and its connection ?
Can you make a picture of the connection?
More important : The floppy drive is the first or the second drive ? Switch settings of the HxC ?
n82558
Post by n82558 »
I used a voltage tester to check that the connector was working and its fine. The cable come out of the main board on the emulator, then goes to the hxc, then to the floppy drive. I've set the floppy as drive 1 and the hxc as drive 2 with jumper ID1A on and everything else off
n82558 wrote:I used a voltage tester to check that the connector was working and its fine. The cable come out of the main board on the emulator, then goes to the hxc, then to the floppy drive. I've set the floppy as drive 1 and the hxc as drive 2 with jumper ID1A on and everything else off
mhh can you try to : put the hxc as drive 0 (id0-a) , disconnect the floppy drive and try to boot the Emu-II from the HxC.
n82558
Post by n82558 »
I've tried that configuration too and it yields the same results. Thanks for all your help by the way, I'm not sure what else to try at this point!
n82558 wrote:I've tried that configuration too and it yields the same results. Thanks for all your help by the way, I'm not sure what else to try at this point!
it doesn't start on the emu_os image ? Does the emulator reacting when the emulator II try to start ?
Have you another machine (PC ?) to try the floppy emulator ?
brettb
Post by brettb »
I am having the same problem on my DPX1. Nothing was happening and the RA..... was displayed on the LED. I flipped the cable around so it looks upside down and the "RA" is gone. and it just displays the "T" message. When I try and load an HFE it now lights up the HxC and tries to load. But alas, the error light starts flashing now.
Andras
Re: Emulator II+ HxC won't load floppy images (INSERT PERF DISK)
Post by Andras »
Hi Gents,
A friend of mine has faced exactly the same problem recently. Did you get to any conclusion or - even better - to a working solution? Please, let me know. Thank you.
András
Andras wrote: Sun Jan 16, 2022 7:09 pm Hi Gents,
András
Which problem exactly ?
Andras
Post by Andras »
Well, I might need to correct myself... So, it is probably not exactly the same case but very similar. Here is the thread opened for my problem:
viewtopic.php?f=16&t=4183
Best regards,
András
