Can the HxC be used to image floppies?
davmp
Post by davmp »
I spent an hour or two last night digging into the web pages and forum and I couldn't positiviely determine whether or not the HxC USB can be used to create images of Ensoniq floppies in some way?
I did see that the software has a button to create an image. But I couldn't find anywhere on the hardware description pages that it mentioned you can use the device as a controller for a real floppy. Does that software feature only work if you have a built-in floppy and controller in a PC?
It would be awesome if there was a USB device that could be hooked up to a modern, floppy-less PC or Mac that would work to image floppies!
Re: Can the HxC be used to image floppies?
davmp wrote:I spent an hour or two last night digging into the web pages and forum and I couldn't positiviely determine whether or not the HxC USB can be used to create images of Ensoniq floppies in some way?
The HxC Floppy Emulator, is a floppy disk drive emulator.
There is some stuff with the hxc software to dump disks but if you want something designed to dump disks , have a look to the Kryoflux project : http://www.kryoflux.com
