Amiga changing disks from Workbench proof of concept
SavourySnaX
Post by SavourySnaX »
First of all, thank you for this amazing device. Thanks to the fact the floppy selector sources are on SVN, I was able to put together this quick proof of concept of selecting files while in workbench without rebooting. Proof of concept video is : http://www.youtube.com/watch?v=5IWl3mThzkU
Apologies for the shaky nature of things, I had the phone in one hand and too much coffee :) Also the intuition window is a bit of a hack (hence the artifacts). It needs cleaning up and support for paging the screen adding (at present it only lists the first 17 files in a directory) ..
Lee
Re: Amiga changing disks from Workbench proof of concept
Very nice ! :D
Do you have a sourcforge account ? ;)
By curiosity which development environnement are you using ?
SavourySnaX
Thanks.
I don't have a sourceforge account - but I can create one, be sometime next week I suspect.
I need to at least clean up the places where i hacked things out (I had to remove the original gui - something about it was causing GURUs on exit - so i chopped it all out and substituted the one in the video). Mostly its just adding some code to lock the device and adding some code to free things on exit.
I`m using AmiDevCpp (http://amidevcpp.amiga-world.de/) and a CF card to copy the resultant bin to my amiga.. (this is a painful way to do things frankly, but saved me farting around getting gcc up and running on the amiga).
Anyway, I`ll let you know when i've created an account in case you want to take the modifications.
Lee
Interesting, i will try AmiDevCpp next time.
I fully understand about gcc on the amiga: i am also working with crosstools on pc to develop on ST & Amiga & CPC too ;)
I don't use CF but an USB HxC Floppy Emulator : The PC makefile automatically mount the image to the Amiga/ST.
Very convenient :) .
Arnie
Post by Arnie »
This looks very promising. If it works then the slim will be much improved.
Keep up the great work Jeff and SavourySnaX 8)
SavourySnaX
Quick update,
What I plan to do this weekend is put together a basic command line version of the application (so you can list directories, list slots, and select images into slots etc). With the command line version done, I can then investigate putting together a gui - the primary motivation behind this method is keeps the amount of modifications to the floppy selector at a minimum and would potentially allow a dopus plugin or similar to be knocked up quickly.
It may be possible to get the fullscreen floppy selector gui stable enough to have that available - it depends on if I can motivate myself to find the problem with the shutdown when under workbench.
Lee
Arnie
Post by Arnie »
Let me know if you need a tester for the slim, I have a Amiga 500, 600 & 1200 to test it on.
Votality
Post by Votality »
Hi SavourySnaX,
Great work! Amy chance of getting a copy of the source as is?
QkiZ
Post by QkiZ »
Bump! There is a chance to get copy of this software?
Kokos
Post by Kokos »
SavourySnaX wrote:Quick update,
Lee
Hi SavourySnaX!
Is this application released already? I can say lot of people would find it very handy! Please give us some response! Thanks.
K
Zeph
Post by Zeph »
Have you gotten anywhere with this? Would be super useful!
Graham
