ASR 10 wont boot
Crocket
ASR 10 wont boot
Post by Crocket »
Hi.
New to this helpfull forum.
ASR 10 with SD Floppy Emulator rev. F bought 1 month ago.
I formatted a 4Gb. Class6 card with FAT 32
Put on the quick Floppy/ Ensoniq files. just copied from laptop to SD card.
When trying to boot the ASR 10, it says loading but stops with the famous error 040.
Drive ID is 1
It should all be very simple but what could I be doing wrong ?
For all help
Thanx
Re: ASR 10 wont boot
Try to reconnect the floppy cable to the other way (colored wire to the other side).
Crocket
Post by Crocket »
Hi Jeff
100 % sure that flatcable orientation is correct, tried reversing anyway, :D
Please look at video file of emulator display when trying to load ASR 10 OS.
thanx
IMG_0999 (2).zip
(236.22 KiB) Downloaded 759 times
mhh very strange. Are you sure that the flat cable is not damaged ? Maybe you should try another one.
Anyway i send to you a new firmware to try.
By email :
Crocket wrote: Yes, 2 hours ago I downloaded latest firmware and now my ASR 10 works.
Thanx so much
