model SD HXC slim and Amstrad CPC 6128 internal connector.
DrLivingstone
Post by DrLivingstone »
Hello.
Someone could tell me what the cable layout to install a slim HXC SD 6128 internally.
This means pass from the 26-pin connector to the controller 34 of the HXC.
I followed the instructions cpcwiki page, but it does not work. It can't read the SD content.
Imagen del CPCWIKI
Mi cable
The SD is formatted in FAT32 and after the HXCSDFE.CFG, AUTOBOOT.hfe
The pin is placed at position 1 ON
Then I found this picture in another forum thread.
https://hxc2001.com/floppy/forum/viewtopic.php?f=8&t=259
I made ​​a mess.
I uploaded a video to youtube of what happens.
http://www.youtube.com/watch?v=5hri4Wnn ... load_owner
I would appreciate any help.
Last edited by DrLivingstone on Sun Jul 21, 2013 4:16 pm, edited 2 times in total.
DrLivingstone
Re: model SD HXC slim and Amstrad CPC 6128 internal connec
Someone who has purchased the SD Floppy Emulator SLIM and installed on an Amstrad CPC 6128 as FD0 could help me about how you have to install?
I think I bought a brick.
DrLivingstone
Solbentado. Las conexiones que reflejan Cpcwiki para la conexion interna estan mal.
Subire unas fotillos para que le echeis un vistazo en funcionamiento. el software de hxc esta muy bien, me ha gustado
You should get this :
http://www.ebay.fr/itm/Amstrad-CPC-664- ... 35c97e93f0
Anyway try to reconnect the floppy cable to the other way at the hxc side : the connector doesn't seems to be connected in right way on your video.
DrLivingstone
Here you have the performance test.
I tried to use an SD (SDHC Type 10) 8Gb, 4Gb with games, but the program goes wrong, it seems to hang. Now I use a 1Gb, I have fewer games but it works well.
Again, the map pin to the inner wire is in wikiCPC not right. I will put a new post with a picture of the connections.
