ensoniq mirage dsk 8 problem
iorobyy
Post by iorobyy »
Hello!
I've a problem with ensoniq mirage dsk8 keyboard.
I try to load operating system, i choose the os32.hfe file in hxc, then i reset the mirage.
Loading start but stop almost immediatly at 11/80.
After some minutes (4-5min) loading start again from 11/80 to 27/80 :?: :?: :?: and operating system seem to be fully loaded :shock: .
Now if i try to load any other disk image (samples) loading stop always at 02/80 and mirage display show "nf" not formatted disk
What's the problem?
I think something not ok in configuration or for ribbon cable.
Hxc is configured as RA / id0 , ribbon cable is reversed on the motherboard as i read in another post.
(if ribbon cable not reversed on mother board side , no loading at all)
Re: ensoniq mirage dsk 8 problem
iorobyy wrote:Hello!
Have you tried to change the interface mode ? (remove the sd, press select -> Interface cfg).
iorobyy
Post by iorobyy »
Thanks Jeff!
Some info to add?
I've tried to change configuration in shugart but loading problem still the same.
What other configuration combination could i try?
iorobyy wrote:Thanks Jeff!
Some info to add?
Update the firmware (in your email box)
Then :
start the dsk8, once done format one of your image with the dsk8 and send me back the HFE file (the OS file and the formatted HFE image )
iorobyy
Post by iorobyy »
Nothing...i cant load anything...only the os after 5 minutes of waiting.
I dont know how to format without the frmt disk image.
Some infos/instructions to add.
very strange...its strange that emulator work with reversed ribbon cable,
it's strange the pause during loading the os ....the problem is configuration i think :(
boh....strange concept of compatibility
iorobyy wrote: boh....strange concept of compatibility
What do mean exactly ?
I am very sorry, but without any pictures of your setup (The HxC + jumper/switch settings,the old floppy disk drive model + the jumper setting, the images that your are trying to use (HFE & sources img), i will have a lot of difficulties to help you...
unfortunately, i am not a soothsayer ;)
Please send me all of this.
iorobyy
Post by iorobyy »
Uh...apologize...sorry but my english is not so good.
I mean that configuration is not so simple , maybe the standard manual
need to be implemented.
However i'll take some pic when possible.
iorobyy wrote:Uh...apologize...sorry but my english is not so good.
Send your disk images too.
wavetermb
Post by wavetermb »
I´m almost having the same issues,
Mirage DSK-8
HXC Rev C SD-Card reader V 1.7.0.0 Firmware.
FAT32-formatted Kingston SD HC 4GB card
Files installed on card is the default HXCSDFE.CFG file, OS32 and MASOS downloaded from elsewhere here.
It will load up to track 11 and then pause. Resuming after a minute or so and load the OS.
Why does it pause ?
Also, I could use a known working sound-disk image to verify that the Mirage functions properly.
WT
wavetermb wrote:I´m almost having the same issues,
Mirage DSK-8
Why does it pause ?
vvvv
Jeff wrote: I am very sorry, but without any pictures of your setup (The HxC + jumper/switch settings,the old floppy disk drive model + the jumper setting, the images that your are trying to use (HFE & sources img), i will have a lot of difficulties to help you...
wavetermb wrote: Also, I could use a known working sound-disk image to verify that the Mirage functions properly.
Is it a question ?
wavetermb
Post by wavetermb »
Actually, it started working....
It needed a good warm up. Now even the original diskdrive functions.
I´ll proceed to copy the disklibrary now and make images of it.
WT
