Akai MPC 60 MKII with SD Floppy Emulator REV F
a.smiddy
Post by a.smiddy »
Hi everybody,
sorry for my bad englisch :D
I have a problem with my MPC60 MKII and the SD Floppy Emulator REV F. The Rev F is already installed in the MPC and the images + HXCSDFE.CFG are on my SD card (the ready files from "ready images for different devices"). The Rev F recognize the files but my MPC60 not. My MPC tells that is no floppy disk in the floppy drive when I want to load or tells that the file is protected when I want to format.
I need your help. What is my mistake?
Best regards
Artur
Re: Akai MPC 60 MKII with SD Floppy Emulator REV F
Is the floppy cable connected to the right way ? Try to connect it to the other way.
a.smiddy
Post by a.smiddy »
thanks for your response. what is the other way?
a.smiddy
Post by a.smiddy »
any response?????
a.smiddy wrote:any response?????
the colored wire of the floppy cable to the other side ...
a.smiddy
Post by a.smiddy »
thanks Jeff, I will try it tomorrow
regards
a.smiddy
Post by a.smiddy »
you are the king. It works. Thank you very much :D
Best regards
