command line tool hxcfe - HxCFloppyEmulator
Cyprian
Post by Cyprian »
Hi All,
I'd like to automatize some of my work, therefore I'm trying to use hxcfe (from command line) as a replacement of HxCFloppyEmulator,
I run hxcfe with:
hxcfe -usb:1 -doublestep -finput:DD_Floppy.msa
and see following output:
HxC Floppy Emulator : Floppy image file converter
Copyright (C) 2006-2012 Jean-Francois DEL NERO
under certain conditions;
libhxcfe version : 2.3.4.2
Input file : DD_Floppy.msa
Starting usb emulation - DD_Floppy.msa
Starting CPLDFloppyEmulator Hw manager...
Loading ftd2xx.dll...
FTDI library loaded successfully!
Device ok !
Checking DD_Floppy.msa
File loader found : ATARIST_MSA (ATARI ST MSA Loader)
Loading DD_Floppy.msa
file loader found!
track file successfully loaded and encoded!
USB HxCFloppyEmulator :Convert track data...
Starting emulation...
Interface mode : ATARIST_DD_FLOPPYMODE
Select line : 1
Double Step : yes
type q and enter to quit
but my Atari ST doesn't see that floppy disk. The same MSA file works fine with HxCFloppyEmulator
did I missed something?
thanks
Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm
http://260ste.atari.org
Re: command line tool hxcfe - HxCFloppyEmulator
Why did you activate the double step ?
The select line should be 0.
Cyprian
Post by Cyprian »
I tried both options with and without "-doublestep"
thanks I will check -usb:0
Cyprian
Post by Cyprian »
thanks Jeff, works ok now
