Copying Floppy disks from DF1: to DF0: (SD HxC)
PulseSeeker
Post by PulseSeeker »
Is it possible to copy real floppy disk (in DF1:) to the SD HxC setup as DF0: ?
In DF0: there is an image.hfe which was formated on the Amiga. When i try to copy a disk via amiga-shell (diskcopy df1: to df0:) i always get the error message "Error on checking disk in DF0:"
mr_options
Re: Copying Floppy disks from DF1: to DF0: (SD HxC)
Post by mr_options »
PulseSeeker wrote:Is it possible to copy real floppy disk (in DF1:) to the SD HxC setup as DF0: ?
I've got the same problem, the diskcopy function works very bad. Try the option (NOVERIFY).
I'm trying to copy from df0: to df1: .... (my HxC Rev.F is in an external case).
If it is an AMIGADOS disk, then it can be copied file by fie (the COPY function).
For non dos disks, I've heard about the X-COPY NEXT GEN to perform the task just fine.
I've download it , but haven't tested it yet .
Please have a look to this (same subject):
https://hxc2001.com/floppy/forum/viewtopic.php?f=5&t=1186
