SD Cased Version
Can the "floppy disk", i.e., the image file, be formatted on the host system using its standard format utility? Under CP/M, the fromat utility writes "E5" to every sector so I can't see why this should not work.
I have seen various posts suggesting that it can't, but this is not mentioned in the manual?
regards
Dave
Image formatting on target hardware
Re: Image formatting on target hardware
This can be done now. But only as beta testerstevendt wrote:SD Cased Version
regards
Dave
There is a new firmware allowing the low level formating.
The firmware is in your email box.
Thanks Jeff!
regards
Dave
regards
Dave
