SDHxCFE Slim RevA with Amstrad CPC External Drive
Greg.0
Post by Greg.0 »
Hello Jeff,
I just received my new Slim version today and tried to use it in replacement of my actual RevC version.
I can't get it work.
Is there a particular dip switch position on your board for the CPC ? The current config is 1ON others off (default Lotharek set up)
I use my SD card with last Emulator Manager V2.5
I don't know the firmware revision of the board...
On my CPC, I have a "bad command" error when I try a "CAT" command.
How is use the button ?
Thank you for your help and congratulation for your great work !
Re: SDHxCFE Slim RevA with Amstrad CPC External Drive
For sure this is not the right jumper setting.
Please have a look to this :
https://hxc2001.com/download/floppy_driv ... FT_ENG.pdf
And set the same ID setting as your RevC
Greg.0
Post by Greg.0 »
Thank you so much for your link.
I had not seen this one on your Documentations main page.
Greg.0 wrote:Thank you so much for your link.
Yes this is a draft, i need to complete it ;)
