Complete Newbie
dcdrac
Complete Newbie
Post by dcdrac »
Just got the HXC 2001, I have created the config file and tried different jumper settings however my cpc6128 does not see the drive.
So I do need a simple join the dots guide.
Step 1. Formatted the SD
Step 2 created the HXDFES config file
Step 3 What jumper settings do I need to get the CPC to see the floppy emulator as the A:drive?
Step 4 What is the ideal COnfig file settings?
dcdrac
Re: Complete Newbie
Post by dcdrac »
This Is how I have set the jumpers on the floppy emulator as I think the manual states it should be fro a Drive B for the 6128
Re: Complete Newbie
dcdrac
Re: Complete Newbie
Post by dcdrac »
Thank you for the reply currently trying to get it to ID as drive B as per the manual however the 6128 tells me Drive B Disc Missing when I type |b
Jumpers currently set for B
Re: Complete Newbie
Just set this setting without the strap on the floppy cable. :
https://hxc2001.com/download/floppy_driv ... ection.jpg
dcdrac
Re: Complete Newbie
Post by dcdrac »
Thank you for replying changed the jumper setting again still is not reading discs in B
Should I have changed the drive cable around too?
Re: Complete Newbie
dcdrac wrote:Thank you for replying changed the jumper setting again still is not reading discs in B
As on the picture!
dcdrac
Re: Complete Newbie
Post by dcdrac »
We have a bingo situation thank you that's worked....
