Just got ref F not getting it to work
aaking76
Post by aaking76 »
Hello Jeff,
After getting my 950 to work, I thought to try my emax...
It seems stuck on " Please insert disk"
If I reverse the floppy cable then the display shows nothing with all the lights on the machine on, like it is frozen...
The emulator seems to power on and work like my other one, but both red lights stay on...
Also, when we we installing it, we accidently put the power cable on wrong, and powered the machine on, and heard a pop, and a weird smell, so I am wondering if I fried my emulator...
The machine seems to work with the original floppy, so if anything I might have fried the emulator, although it seems to work, display, will page through images, and I can adjust settings, all seems well, but of course it is not actually working ...
Any help would be great, I hope I didn't blow 160 bucks....lol
aaking76
Re: Just got ref F not getting it to work
Post by aaking76 »
we were one pin off on the power,
First :
-> Remove the SD Card -> Press select -> Choose " Clear eeprom"-> yes.
-> Set the Switch setting to ID0-A
-> Please use the emax images present in this file :
aaking76 wrote: If I reverse the floppy cable then the display shows nothing with all the lights on the machine on, like it is frozen...
And if you reverse the floppy cable ?
aaking76
Post by aaking76 »
So I cleared the eprom, and loaded the images you provided in the root folder on the sd card...
Still is saying insert disk...
Should I reverse the cable again now that eprom is cleared?
aaking76
Post by aaking76 »
I reversed the floppy cable, and then all the lights on the emax go on, and the display is blank, but lit....
If I put the cable on the other way it will say insert disk....
aaking76 wrote: If I put the cable on the other way it will say insert disk....
And do you see on the HxC screen in this case ? how are the HxC leds ?
aaking76
Post by aaking76 »
both red lights are on and I can page through the files, and load images, appearing normally as my other one...
The emax will just sit there and say "Please insert disk"
aaking76
Post by aaking76 »
Is there any diagnoses that I can do to make sure I didn't ruin anything?...
Like I said I might have reversed the power on accident...
aaking76 wrote:both red lights are on and I can page through the files, and load images, appearing normally as my other one...
So in this case please reverse the floppy cable.
If all HxC led are always on, the cable is probably is connected to the wrong way.
Anyway on Emax : Colored floppy cable wire = Pin 34/33.
Please choose an HFE and take a picture of the HxC LCD.
aaking76
Post by aaking76 »
The top 2 are the floppy cable one way, and the bottom is with it reversed....
aaking76
Post by aaking76 »
Pictures requested of all led states, with floppy cable both ways and unplugged...
Any Help is greatly awesome....
Thanks Jeff
ESTEGAL91
Post by ESTEGAL91 »
Same problem, still not solved ?
Reconnect the floppy ribbon to the right way, and then the problem is solved...
