command line tool hxcfe - getfile/putfile
krupkaj
Post by krupkaj »
hi,
please could you explain me how to put/get files to/from image by command line tool hxcfe?
I found out how to convert files from msa image to hfe and how to create empty hfe file. But I do not understand how options -getfile and -putfile work.
thanks.
krupkaj
Re: command line tool hxcfe - getfile/putfile
Post by krupkaj »
nobody knows? :(
krupkaj wrote:nobody knows? :(
hxcfe -finput:Disk_Image.hfe -putfile:thefile.txt
hxcfe -finput:Disk_Image.hfe -list
hxcfe -finput:Disk_Image.hfe -getfile:/thefile.txt
krupkaj
Post by krupkaj »
Thanks! I use -foutput when tried to write a file and did not use the / when getting the file from image.
Is it possible to create image file with FAT12 filesystem? I tried
hxcfe -foutput:test.hfe -uselayout:DOS_DD_720KB -ifmode:ATARIST_DD_FLOPPYMODE -conv:HXC_HFE
it creates the image but it is not possible to write a file into it.
krupkaj@mini:~/HxC/export$ hxcfe -finput:test.hfe -putfile:test.txt
HxC Floppy Emulator : Floppy image file converter
Copyright (C) 2006-2012 Jean-Francois DEL NERO
under certain conditions;
libhxcfe version : 2.3.4.2
Input file : test.hfe
File Image: test.hfe
Checking test.hfe
File loader found : HXC_HFE (SD Card HxCFE HFE file Loader)
Loading test.hfe
file loader found!
File type : HXC_HFE - SD Card HxCFE HFE file Loader
Floppy interface mode : ATARIST_DD_FLOPPYMODE
Number of Track : 80
Number of Side : 2
Put test.txt
Files size : 21 Bytes
Write HFE file test.hfe for the standalone emulator.
Floppy interface mode ATARIST_DD_FLOPPYMODE (Atari Interface (720KB/DD Disk))
80 tracks written to the file
Stopping HxCFloppyEmulator...
krupkaj@mini:~/HxC/export$ hxcfe -finput:test.hfe -list
- File image browser -
File: test.hfe
Checking test.hfe
Loading test.hfe
file loader found!
Number of Side : 2
Total Size : 737280 Bytes, Number of sectors : 1440
------- Disk Tree --------
Use the GUI to create the dos image.
Why do you want to use the command line tool?
krupkaj
Post by krupkaj »
Because I have not Windows machine. I tried the Linux GUI version but as I wrote in Raspberry Pi thread the drag & drop does not work properly. I have no problem with using command line tools. It would be even better if it runs on Atari under MiNT. But I did not try to compile it yet.
edit: I have just read the other thread and I am downloading the source tree :-)
krupkaj wrote: edit: I have just read the other thread and I am downloading the source tree :-)
Good idea ;)
Cyprian
Post by Cyprian »
Hi Jan,
what about Thomas's converter? It converts PRG files into ST disk.
http://manpages.ubuntu.com/manpages/pre ... 2st.1.html
http://hg.tuxfamily.org/mercurialroot/h ... /zip2st.sh
Is it ok for you?
[EDIT]
there is also Leonard's dir2msa:
http://dhs.nu/bbs-scene/index.php?request=16129
Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm
http://260ste.atari.org
audric
Post by audric »
Jeff wrote: Wed Apr 03, 2013 10:24 pm
in my case the file to be put in the images has to be inside a directory.
ie:
\MYDIR\myfile.txt
I need to inject the file in the image via commandline.
Is this possible?
