Rev F casing not quite 1 to 1
tuf
Post by tuf »
I just tried fitting my Rev F into a standard 3.5 to 5.25 adapter and it's not fitting at all. The Rev F face is too wide and tall to fit in a standard 3.5 inch opening. I confirmed this with 2 Rev Fs and a variety of devices (DPX-1 for instance).
I also notice that the included screws don't thread properly - matter of fact I cant find any screws that thread into it.
Anyone else having issues like this or did I just get a weird batch (both of my Rev Fs are like this).
Re: Rev F casing not quite 1 to 1
Yes if you get the first batch, this is possible that there are some mechanical problems. This should be solved now but i prefer that Lotharek confirm this point.
When did you got your RevF emulators ?
tuf
Post by tuf »
Jeff wrote:Yes if you get the first batch, this is possible that there are some mechanical problems. This should be solved now but i prefer that Lotharek confirm this point.
I got my original one just after they first came out, but the two I'm testing with now I bought in August 2012. All 3 have the issues fitting into 3.5 inch bays.
tuf wrote: I got my original one just after they first came out, but the two I'm testing with now I bought in August 2012. All 3 have the issues fitting into 3.5 inch bays.
ok this was the first batch. There was some mechanical fitting with some devices. This should be corrected. Anyway Lotharek will check all these points.
lotharek
Post by lotharek »
in 99% batches 1-6 were mechanically OK for most devices..
this 1% was corrected in every unit bought this year.so, all units now are improved
..... Atari Roxxx !!!
tuf
Post by tuf »
lotharek wrote:in 99% batches 1-6 were mechanically OK for most devices..
How did you correct them? It looks like id have to bend the front panel to make them fit properly, and that'd require a machine to do.
Would it be possible for me to just get the trays from you so I could replace these?
tuf
Post by tuf »
Bump, these are hard to use, especially in Oberheim DPX-1s which have a thick metal opening for the 3.5 inch floppy :(
lotharek
Post by lotharek »
contact me to personal mail so i could help
