Can't Load an EDE File
mrfett
Post by mrfett »
I have images I made with Omniflop. They had .img extensions. I've tried changing the extension to .EDE but can't get HxCFloppy Emulator v.2.0.11.1 to load them. If I use "Load Raw Image" to load them it works, but that doesn't seem to allow you to batch convert to HFE. What am I doing wrong? I am on a Mac but just tried to use the files on a PC and got the same error. I also got the error on the non-beta version available for PCs.
Re: Can't Load an EDE File
mrfett wrote:I have images I made with Omniflop. They had .img extensions. I've tried changing the extension to .EDE but can't get HxCFloppy Emulator v.2.0.11.1 to load them. If I use "Load Raw Image" to load them it works, but that doesn't seem to allow you to batch convert to HFE. What am I doing wrong? I am on a Mac but just tried to use the files on a PC and got the same error. I also got the error on the non-beta version available for PCs.
EDE != IMG !
If you want import img/raw ensoniq image, please use the attached cfg file.
ensoniq.zip
(197 Bytes) Downloaded 699 times
mrfett
Post by mrfett »
OK, so there's no way to batch convert to HFE?
mrfett wrote:OK, so there's no way to batch convert to HFE?
In the next release it will be possible to batch convert raw file.
I hope to release this new version today.
mrfett
Post by mrfett »
You are amazing! Thank you so much!!!
mrfett wrote:You are amazing! Thank you so much!!!
Done :
mrfett
Post by mrfett »
Seems to be working! Thank you so much, I spent weeks making tons of Omniflop images. Importing each one separately was not something I was looking forward to.
