directory sorting
antti
directory sorting
Post by antti »
my 3.5 HxC SD works fine (plugged in a a4000 :)
I have a smalll but annoying problem:
when booting from AUTOBOOT.HFE, directory listing is not alphabeticaly sorted, is this a solution for it ?
Thank You for your response
Re: directory sorting
Yes just search for "fat32 file sorter" on google.
antti
Post by antti »
g r e a t :)
didn't know this existed :)
elpiloto
Post by elpiloto »
i had the same question, great info, thank you!
QkiZ
Post by QkiZ »
It's possible to implement sorting function in HxC?
mr_options
Post by mr_options »
I have the same problem when I use with SD devices like :
-HxC floppy emulator
-SIO2SD (for atari 8 bits)
I use use the "FAT sorter" program on both, and it works great FOR BOTH.
Maybe this option may be included.
But for the moment, no such option available.
