Emax EB1 files and HxC floppy emulator..
mrdazobee
Post by mrdazobee »
I just created an EB1 image of some 16bit wav files using the EMXP software.But when I try to load that into the HxC software it says load error,file not supported.It works with EM1 files so what is the difference between EM1 files and EB1 files.Any idea how to make this work?
Re: Emax EB1 files and HxC floppy emulator..
EM1 = Disk image
EB1 = Only a bank
So you need to generate an EM1 from the EB1 with emxp.
mrdazobee
Post by mrdazobee »
Thanks again Jeff I did actually figure it out after a little searching.EMXP and HxC working great together now!
