IO Error on CoCo
yell0w_lantern
IO Error on CoCo
I just got a CoCo 3 and I cannot get the HxC to load anything.
I previously had some trouble getting it going ona CoCo 2 until I figured out I was using tghe cassette load command instead of disk and I found taht I had to reset the computer before accessing the HxC. This second issue is strange to me in that if I try to access HxC files without reseting the CoCo2 I get "IO error" - I don't understand why a reset takes care of this.
On my CoCo3 I get the IO error message as well except that it does not resolve with a reset.
I'm using a standard CoCo disk controller but the previous owner did install ADOS on it. Could ADOS be the problem, am I doing something wrong or do I have a bad HxC. I am especially concerned about the last possibility because I cannot load any TI games through the PEB either although I can access the disk from inside a game like Tunnels of Doom.
Re: IO Error on CoCo
Which Floppy Emulator ?yell0w_lantern wrote:I just got a CoCo 3 and I cannot get the HxC to load anything.
Firmware version ?
Jumper setting ?
Interface mode setting ?
Floppy cable used ?
yell0w_lantern
Which Floppy Emulator ? Lotharek Rev C cased
Firmware version ? 1.7.2.7
Jumper setting ? Straight on from the back it looks like this
I . . .
I I . .
. I . .
Interface mode setting ? Not sure what you mean here
Floppy cable used ? Card edge to 34 pin no twist
I . . .
I I . .
. I . .
Last edited by yell0w_lantern on Mon Mar 04, 2013 8:53 pm, edited 1 time in total.
mhh according to the user manual the jumpers should at the other side, isn't it ?yell0w_lantern wrote:Which Floppy Emulator ? Lotharek Rev C cased
Jumper setting ? Straight on from the back it looks like this I . . .
I I . .
. I . .
yell0w_lantern
My point of reference is from the back of the device. From the front (can't see it from the front but if you could:Jeff wrote:mhh according to the user manual the jumpers should at the other side, isn't it ?yell0w_lantern wrote:Which Floppy Emulator ? Lotharek Rev C cased
I I . .
. I . .
. . . I
. . I I
. . I .
A couple of the pins for the 34 pin connector are not flush with the others and have recessed somewhat. When I was trying to get the TI-99 and the CoCo2 to work before, I pulled them flush again using needle nose pliers but it did not seem to make a difference for either machine before.
Still a problem : For me this should be this :yell0w_lantern wrote:My point of reference is from the back of the device. From the front (can't see it from the front but if you could:
. . . I
. . I I
. . I .
. . I .
. . I I
. . . I
yell0w_lantern
Changed jumper settings and no difference.Jeff wrote:Still a problem : For me this should be this :yell0w_lantern wrote:My point of reference is from the back of the device. From the front (can't see it from the front but if you could:
. . . I
. . I I
. . I .
. . I .
. . I I
. . . I
Overwrite your cfg file.
And the update your firmware with the one present in your email box.
I'm having the same IO ERROR here. Just renamed the original DSK Coco files, found everywhere on the net, to JVC and exported to the SD. When make a DIR, it just reads to track 17 and keep repeating. Never passes track 17.
My SD emulator have firmware 0.2.2.0.
Daniel
Daniel
Send me the DSK & HFE files, i will check this.Dantyr wrote:Hello,
Daniel
Follow both the HFE and DSK (renamed to JVC) that I used. The same occur with others as well.
Daniel
Daniel
- DSKs.zip
- (230.4 KiB) Downloaded 864 times
Hi,Dantyr wrote:Hi Jeff,
Daniel
the files look good.
Regarding the firmware version your are using, i suppose that you are using the prototype version?
I am not sure that this hardware version is able to drive the 150ohms pull up present in the Coco.
as far i remember the floppy interface on the prototype used 74LS05 -> 8mA of driving max.
I'm using one buit here in Brazil, but based on a russian project. Here pics:
On the board there is two LS01, one LS14 and one LS08.
Daniel
Daniel
Well this was one of the designs flaw present in this old prototype version : The buffer used here are not able to drive floppy bus with 150ohms pull up.
Are you sure that you don't want to get the lastest slim version ?
http://lotharek.pl/product.php?pid=91
Nice! But where the LCD display go on that design ?
Daniel
Daniel
