CP/M Disk Definitions for Drive Parameters
ldkraemer
Post by ldkraemer »
I'm wondering if you have a need for the OLD CP/M Drive Definitions? I've saved several Euro Definition files, along with some
that I've created. I've attached a sample for the Radio Shack Model Computers.
BEGIN TRSD TRS-80 Model 4P - Montezuma 800K - DSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 2 SECTORS 10,512
SIDE1 0 1,3,5,7,9,2,4,6,8,10
SIDE2 1 1,3,5,7,9,2,4,6,8,10
ORDER SIDES
BSH 4 BLM 15 EXM 0 DSM 399 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSH TRS-80 Model 4,4P Montezuma System 170K - SSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 1 SECTORS 18,256
SIDE1 0 1,3,5,7,9,11,13,15,17,2,4,6,8,10,12,14,16,18
BSH 4 BLM 15 EXM 1 DSM 84 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSI TRS-80 Model 4,4P Montezuma Data 200K - SSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 1 SECTORS 10,512
BSH 4 BLM 15 EXM 1 DSM 99 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSJ TRS-80 Model 4,4P Montezuma System 350K - DSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 2 SECTORS 18,256
SIDE2 1 1,3,5,7,9,11,13,15,17,2,4,6,8,10,12,14,16,18
ORDER EAGLE
BSH 4 BLM 15 EXM 1 DSM 174 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSK TRS-80 Model 4,4P Montezuma Data 400K - DSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 2 SECTORS 10,512
ORDER EAGLE
BSH 4 BLM 15 EXM 1 DSM 199 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSL TRS-80 Model 4,4P Montezuma System 350K - SSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 1 SECTORS 18,256
END
BEGIN TRSM TRS-80 Model 4,4P Montezuma Data 400K - SSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 1 SECTORS 10,512
END
BEGIN TRSN TRS-80 Model 4,4P Montezuma System 710K - DSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 2 SECTORS 18,256
ORDER SIDES
BSH 4 BLM 15 EXM 0 DSM 354 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSO TRS-80 Model 4,4P Montezuma Data 800K - DSDD 96 tpi 5.25"
DENSITY MFM, LOW
ORDER SIDES
END
BEGIN TRSP TRS-80 Model 4,4P Montezuma Extend System 190K - SSDD 48 tpi 5.25"
DENSITY MFM, LOW
BSH 4 BLM 15 EXM 1 DSM 94 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSQ TRS-80 Model 4,4P Montezuma Extend System 390K - SSDD 48 tpi 5.25"
DENSITY MFM, LOW
ORDER SIDES
BSH 4 BLM 15 EXM 1 DSM 194 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSR TRS-80 Model 4,4P Montezuma Extend System 390K - SSDD 96 tpi 5.25"
DENSITY MFM, LOW
BSH 4 BLM 15 EXM 0 DSM 194 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRSS TRS-80 Model 4,4P Montezuma Extend System 790K - DSDD 96 tpi 5.25"
DENSITY MFM, LOW
ORDER SIDES
BSH 4 BLM 15 EXM 0 DSM 394 DRM 127 AL0 0C0H AL1 0 OFS 2
END
BEGIN TRST TRS-80 Model 4,4P Montezuma Super Data 220K - SSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 1 SECTORS 6,1024
SIDE1 0 1,3,5,2,4,6
BSH 4 BLM 15 EXM 1 DSM 109 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSU TRS-80 Model 4,4P Montezuma Super Data 440K - DSDD 48 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 40 SIDES 2 SECTORS 6,1024
SIDE1 0 1,3,5,2,4,6
SIDE2 1 1,3,5,2,4,6
ORDER EAGLE
BSH 4 BLM 15 EXM 1 DSM 219 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSV TRS-80 Model 4,4P Montezuma Super Data 440K - SSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 1 SECTORS 6,1024
SIDE1 0 1,3,5,2,4,6
END
BEGIN TRSW TRS-80 Model 4,4P Montezuma Super Data 880K - DSDD 96 tpi 5.25"
DENSITY MFM, LOW
CYLINDERS 80 SIDES 2 SECTORS 6,1024
SIDE1 0 1,3,5,2,4,6
SIDE2 1 1,3,5,2,4,6
ORDER SIDES
BSH 4 BLM 15 EXM 0 DSM 439 DRM 127 AL0 0C0H AL1 0 OFS 0
END
BEGIN TRSX TRS-80 Model 4,4P Montezuma System 400K - SSDD 96 tpi 3.5"
DENSITY MFM, LOW
END
If you are interested give me a valid email address, and I'll zip the files and upload them.
Larry
Re: CP/M Disk Definitions for Drive Parameters
Thanks, i will have a look to this.
ldkraemer
Post by ldkraemer »
Jeff,
Do you have a need for other Euro CP/M Floppy Definitions?
If so, do you have a FTP site or some site I can upload all of the Euro CP/M Definitions that I have. You might be able
to find/use some of the definitions that you don't already have?
I'm not sure how your software determines the CP/M Floppy's Parameters, but I assume you have some type of table
of Definitions that allow you to setup and read the different floppy's.
Thanks.
Larry
