any way to...
elpiloto
any way to...
Post by elpiloto »
hi, is there any way to connect both, the internal floppy and the floppy emulator on the same floppy cable on an A500 ?
regards
Hernan
Re: any way to...
elpiloto wrote:hi, is there any way to connect both, the internal floppy and the floppy emulator on the same floppy cable on an A500 ?
regards
Hernan
Yes, just use one floppy cable with 3 connectors.
elpiloto
Re: any way to...
Post by elpiloto »
hi, thanks for the reply.
I tryed that allready, Im afraid that is not so simple on A500, because according to the a500 schemattics we have motr0 signal on the floppy connector that can handle one drive instead of mtrx thats on the external port and it can handle more drives
cheers
