SD Floppy Emulator REV F for Piccola L70R
Dmitriy N.Pu
Post by Dmitriy N.Pu »
Hi, I'm from Russia.
Interested in whether the SD Floppy Emulator REV F machine for disclosure glass Piccola L70R?
P.S. Sorry for the curve English. I use google translate..)
Re: SD Floppy Emulator REV F for Piccola L70R
Dmitriy N.Pu wrote:Hi, I'm from Russia.
Yes this should works without any problem.
You can try to make an HFE image file from your floppy disk with the hxc floppy emulator software :
Dmitriy N.Pu
Jeff wrote:You can try to make an HFE image file from your floppy disk with the hxc floppy emulator software :
Do not quite understand what the emulator can help explain please? The machine reads the FDD created, PC program Opty-way ...
With this software you can read an Piccola L70R floppy disk on a PC and export it the HFE file format.
This file will be used by the floppy emulator.
Dmitriy N.Pu
Jeff wrote:With this software you can read an Piccola L70R floppy disk on a PC and export it the HFE file format.
Thanks for the clarification. While awaiting a response, understand how it works.At the moment the order phase emulator, hope will not fail "glands")
Dmitriy N.Pu
Jeff, yesterday I found the floppy ribbon cable to the machine does not replace the train from the PC. This problem can be solved?
Dmitriy N.Pu wrote:Jeff, yesterday I found the floppy ribbon cable to the machine does not replace the train from the PC. This problem can be solved?
A picture please. I want to see this.
Dmitriy N.Pu
For clarity forum visitors upload pictures of the cable to the machine, and the cable for the PC.
PC
PC
the machine
the machine
Look likes the same type of cable. No problem at all.
If you are talking about the twisted part, this is not an issue.
Dmitriy N.Pu
Clear. Well, now we will try to practice as an emulator comes ...
Dmitriy N.Pu
Hi, get your product.
There was a complication. Without the emulator works like this: a program Opty-way (writes only FDD) on the disc, then inserted into the machine ... Now you need a: Opti-way you write to a floppy disk, then create an image, then burn to a SD by creating an image of a cardreader HxCFloppyEmulator_softV2_beta, then insert the SD into the emulator and start working. How to make a standard floppy disk image to be converted into HFE format?
Dmitriy N.Pu wrote:Hi, get your product.
Is it a dos or windows software ?
Can you make a Piccola L70R disk dump with the hxc software ? : https://hxc2001.com/download/floppy_driv ... 2_beta.zip
Dmitriy N.Pu
Yes I can, but I will lay out the evening.
Opty-way windows software...
Dmitriy N.Pu
here...
Floppy Dump.rar
dump
(68.23 KiB) Downloaded 1054 times
Dmitriy N.Pu
it was necessary to try to convert the data to a floppy disk operating PС ...
