What am I doing wrong ?
knarzmaschine
Post by knarzmaschine »
Hi guys,
I had luck with my Studio 440 and Prophet 2002, but somehow I cannot
get my REV F Emulator working with my SP1200 :-(
Doing the same thing as before, tried several SD cards, tried EMU-Shugart, used the images files
from the net (already HFE files), no luck :-( Switches are on ID0.
Somehow it's stuck and the display is switching between "READING FAT" & (c)HxC and then stops !
Any help would be highly appreciated :-)
Best,
Thomas
Re: What am I doing wrong ?
knarzmaschine wrote: Somehow it's stuck and the display is switching between "READING FAT" & (c)HxC and then stops !
All sdcard are doing the same thing ?
First thing to check : the power supply. Power supply failure are very common. Can you check the +5V voltage?
another thing to try : switch off the hxc sound.
knarzmaschine
I tried several different cards and all do the same.
+5V is at +4.67V, but that should be ok ?
Switched off the sound and it's the same.
The original Floppy does work and so does the SP.
Thomas
knarzmaschine wrote:I tried several different cards and all do the same.
Thomas
Can you try to plug the emulator on other computer/instrument (PC...) ?
The SDCard are formatted in FAT32 ?
knarzmaschine
Already put the one I had in the SP into my Prophet 2002 and works like a charm.
SD is formatted in FAT32 of course...for testing I used a 32MB and the HxC says
it's the wrong format. The emulators are fine.
I guess I make a very minor stupid mistake somewhere, but I don't know where.
My process:
- Formatting FAT32 on a PC
- copy the CFG file onto the SD first (AUTO or EMU Shugart, both same results)
- then copy the HFE files onto the card
Usually the SP asks INSERT DISKETTE, but with the emulator it says READING DISK.
But then just stops.
I will try to dump one of my own Floppies and see if they work.
The ones I used were from the net.
Update soon :-)
Just download this and unzip the SP1200 zip on the sdcard :
knarzmaschine
AAAAAAAAAAAAAAAAAAHHHHHHHHHHHHH !!!!
I knew it was a minor but stupid mistake !!!
I connected the cable the wrong way, 1 of the connector is on the oposite side
on the SP.
Thanks for your help and now all is working flawless :D :D :D
Thomas
pfaffian
Post by pfaffian »
What jumper settings did you use for the Studio 440? Mine won't format!
