which config must be used for a roland e-96 keyboard
straatsma
Post by straatsma »
Hello
I received the hxc emulator and installed it in the roland e-96. I formatted a sdhc 2gb and i have to put the config file onto it but which config file will work correctly ? next is the format of the disks a have. the extensions used by roland are *.stl and *.uss how can i convert these files ?
And the keyboard also says disk not ready ?
who can help with the answers.
with kind regards
Re: which config must be used for a roland e-96 keyboard
Can you send me these files please ?
EDIT: the e-96 use DOS formatted floppy ?
If yes download this:
https://hxc2001.com/download/floppy_dri ... 2_beta.zip
"Create FS Floppy"
Select " 3"5 1.44MB DSHD FAT12 " -> Create Disk
Drag & Drop your stl/uss files on this window.
On the main window -> export-> HFE file -> Save.
You can use the default settings for the config file.
straatsma
Post by straatsma »
Thanks to Jeff for his help.
Roland E-96 is fully functional with HxC floppy emulator.
chnuschti
Post by chnuschti »
hello,
which .cfg file do i need to put on the sd card?
while i can find .cfg files for roland mw30, s339 and s760, i can't find any for the e-96?
any help is appreciated, thanks!
chnuschti
Post by chnuschti »
jean-francois from hxc2001 helped out and gave me following information that solved the problem.
"Unzip the attached file to the sdcard. The unzipped files must be in the usb stick root folder.
Set the ID0-A,ID1-A,ID2-A and ID3-A switches to ON (number 1,2,3 & 4)"
that, in the end, worked for me. so, thanks jean-francois!
SDHxCFE_PC_1.44MB.zip
(56.23 KiB) Downloaded 2460 times
