Firmware problem issue
gueri
Post by gueri »
Hello
I have the Rev B since a long time now. I want to upgrade to firmware to 1.7.2.0 but i have 5 flash led error :
"Bad UPD File header"
I done several attempts with formatted sd card but the problem is always the same.
Help!
Re: Firmware problem issue
gueri wrote:Hello
Help!
This is normal because your firmware is very old.
Send me an email, i will send you an special upd file.
gueri
Post by gueri »
Hello Jeff
Thank you very much for your quick response.
OK, I will send you en email.
Regards,
gueri
