Problem with SD Emulator on 480Z
DanWilliams
Post by DanWilliams »
I am having problems using this with a 480Z. But I'm not sure if I am trying to do something that it can't do.
I have been able to read, write to and boot from images. But I cannot get CP/M to write a boot sector. Also if I try to use a diskcopy program to copy a whole disk sector by sector to a floppy image, it fails.
Is this normal behaviour ?
Dan
Re: Problem with SD Emulator on 480Z
DanWilliams wrote: I have been able to read, write to and boot from images. But I cannot get CP/M to write a boot sector. Also if I try to use a diskcopy program to copy a whole disk sector by sector to a floppy image, it fails.
There are 2 flags into the HFE file to indicate that the first track use another format (MFM or FM). This is probably the problem here. Send me the HFE file , i will check/correct it.
DanWilliams
I tried to attach a file, but I cannot find any extension that is allowed.
Dan
DanWilliams wrote:Hi,
Dan
By email please : https://hxc2001.com/contactus/
