Akai MPC 3000
iheartbeets
Akai MPC 3000
Post by iheartbeets »
Looking for definitive jumper settings and hfe blank disk files to get this installed into my 3K. With the Sp1200, it was a piece of cake with the quick install files. Can anybody help?
Re: Akai MPC 3000
iheartbeets wrote:Looking for definitive jumper settings and hfe blank disk files to get this installed into my 3K. With the Sp1200, it was a piece of cake with the quick install files. Can anybody help?
Please use the HxC software to read your actual floppy and export them to HFE then send me the HFE files.
iheartbeets
Re: Akai MPC 3000
Ok jeff will do. Thanks for all the help.
iheartbeets
Re: Akai MPC 3000
Got the 3rd drive for the Akai. Installed it and used the Shugart disk file you sent. The PCHD file did not work. The Shugart with the config file got it going perfectly! I couldn't figure out how to auto load the 3.16 update but aside from that, everything went very smoothly.
Thanks again for your great support help.
Re: Akai MPC 3000
iheartbeets wrote: I couldn't figure out how to auto load the 3.16 update but aside from that, everything went very smoothly.
But the update should be done only once, isn't it ?
iheartbeets
Re: Akai MPC 3000
No. It must be done every time because the operating system is on EPROMS. Before, I had the newer OS on a disk and the machine would autoload it. Oddly, it will not do this with HXC. I wonder if it has anything to do with the config file. Any thoughts?
Re: Akai MPC 3000
iheartbeets wrote:No. It must be done every time because the operating system is on EPROMS. Before, I had the newer OS on a disk and the machine would autoload it. Oddly, it will not do this with HXC. I wonder if it has anything to do with the config file. Any thoughts?
So the MPC doesn't boot on the floppy at power up?
Sveef
Re: Akai MPC 3000
Post by Sveef »
Hello! Jeff can you send me an image for mpc 3000? Thanks
Re: Akai MPC 3000
Sveef wrote:Hello! Jeff can you send me an image for mpc 3000? Thanks
In the ZIP :
Sveef
Re: Akai MPC 3000
Post by Sveef »
Hello everybody! I got the next problem. When i change a floppy my mpc still see the first floppy which i selected at first. What i got to do? Only reboot an mpc?
Re: Akai MPC 3000
Sveef wrote:Hello everybody! I got the next problem. When i change a floppy my mpc still see the first floppy which i selected at first. What i got to do? Only reboot an mpc?
Can you try to change the interface mode into the hxc menu (remove the sd and press select) ?
Sveef
Re: Akai MPC 3000
Post by Sveef »
I tried to change but trouble is stayed
Sveef
Re: Akai MPC 3000
Post by Sveef »
May be i got to change jumper settings?
Re: Akai MPC 3000
Sveef wrote:May be i got to change jumper settings?
Yes ! Try the others one !
iheartbeets
Re: Akai MPC 3000
Okay. I am back to ask a question. The floppy drive in the MPC3000 on had a limited capacity. Is it possible to make the .hfe file size larger so that the machine can take advantage of the new storage capacity? My machine has 32mb of memory but because of the virtual disk size, I can only save 1.44mb at a time so it is a waste. It is my understanding that the machine will create 30mb partitions. What do you think Jeff?
