Problem with rev.F in external housing
DTention
Post by DTention »
I am having trouble getting it to work into a external Amiga disk drive housing.
It does work if i put it inside the amiga but not when i use it in the housing.
Maybee this is just a jumper or config setting but the lack of a userguide for this model does not help me very much.
Anybody got some tips please?
I would love to use this device as external so i can use it on all my amiga's.
Re: Problem with rev.F in external housing
DTention wrote:I am having trouble getting it to work into a external Amiga disk drive housing.
Don't Blame the HxC but the Amiga designers. :
The DS0 signal is not present on external floppy port, so you cannot use any drive as DF0 on the external port without amiga motherboard modification.
It's only for DF1/DF2.
DTention
Post by DTention »
Hello Jeff,
Thanks for the reply, i don't blame anyone (maybee myself) i like the device.
The problem i have is that it also does work (or i just don't get it to) as df1.
Wasn't even thinking of getting the second drive to work but that would be nice also.
The cables in the external housings i tried (2) are not twisted, what jumper settings should i use?
I can't find any guide on the jumper settings for the rev.F product so any advice is much appreciated.
Try ID1-A: on, other : off
DTention
Post by DTention »
Hello Jeff, thanks for the reply....
I tried some more external housings and settings and now got it working as a single drive.
Jumpered it with id0 witch is the same as the original drive in the housing was.
Only problem i have is that i can not use the autoboot file on my A4000, it keeps hanging when it boots from it.
This may be because the drive gets mounted as df2: and i can not find a autoboot.hfe that supports that, i only
found 1 for df0: and 1 for df1:.
Is there a way to get this util also working on a drive that is marked as df2?
Or is there a standalone util that i can run after booting from my harddrive?
why not id1 ?
DTention
Post by DTention »
on the amiga 4000 df1: is reseved for internal use only, even if no second internal drive is used (i have just 1 internal).
If i connect a normal external diskdrive it will be addressed as df2: same as the HxC.
I also dont know of any boot switch for the 4000 so i could fool it in being a df0: or df1: so i could use the existing versions of the autoboot files.
I have not looked at the autoboot images yet but are these files editable so i can boot from it as df2:?
