list of "tested" CF-, SD- and SDHC-Cards available ?
supergau
Post by supergau »
is there a list of "tested" CF-, SD- and SDHC-Cards available, which works with the HxC Emulator or any recommendations ?
i have found some cards on amazon I would order now, but I don't know if they are they ready to run with the emulator...
http://www.amazon.de/SanDisk-SDSDXPA-00 ... 610&sr=8-1
http://www.amazon.de/SanDisk-SDHC-16GB- ... 440&sr=8-6
http://www.amazon.de/SanDisk-Extreme-SD ... 670&sr=8-8
any suggestions ?
Re: list of "tested" CF-, SD- and SDHC-Cards available ?
supergau wrote:is there a list of "tested" CF-, SD- and SDHC-Cards available, which works with the HxC Emulator or any recommendations ?
any suggestions ?
Any SD Card should be ok.
Anyway for better write performance Class 10 SD are recommended.
