RevC to RevF-like upgrade (oled display)
min.struct
Post by min.struct »
as i already own a RevC SD HxC, i'm studying how i could upgrade it to a RevF-like form factor.
My main concern is a smaller deported display.
This is why i was wondering if this OLED display would be compatible with the RevC ?
http://wisechip.en.alibaba.com/product/ ... e_Red.html
this display is only 17.5mm high, so adding another 5mm for the PCB + SDcard holder, it could fit the 25mm high of a standard 3,5" floppy disk drive.
it does exist in two versions. this other version looks fully compatible, but of course with this version the size gain is totally lost :
http://wisechip.en.alibaba.com/product/ ... White.html
http://www.vitek.com.tw/oled-module/oled-6x2.html
here it says :
Built-in controller US2066, COG = chip on glass
So do you think this OLED display could work with RevC 4bits, with an appropriate ribbon cable adapter ?
thanks ;)
Re: RevC to RevF-like upgrade (oled display)
It could but you need to provide the high voltage (12v) for the screen.
min.struct
Hi Jeff, thanks for pointing the 12v problem :?
doesn't the mini-molex (berg connector) provide 12V?
http://pinouts.ru/Power/SmallPower_pinout.shtml
min.struct
i found more information : http://downloads.codico.com/misc/Newsle ... 101022.pdf
MCU communication interface
COG type : • 4/8-bit 80xx/68xx parallel, SPI,I2C
Standard PCB type : • 4/8-bit 80xx/68xx parallel, SPI,I2C • By component / circuit select.
On-chip CGROM ( 5x8 ) English / Japanese / Europe / Russia : • Hardware Select
Programming CGRAM ( 5x8 ) Max. 8 5x8 character
Compatible : IC compatible with KS0066 / PCB version, mechanical and pin are compatible with LCM
Driving Voltage
COG Module need 12V applied
PCB Module using built-in boost circuit or extra 12V power
