sp1200 help required
sp12000
Post by sp12000 »
im trying to install a rev 5 hxc in my sp1200 ,i seem to be stuck and would appreciate any assistance.
So far i've plugged it all in, it powers up ,i ve installed 2 jumpers on pins 4 and 8 ( from above, facing rear, left to right) as shown in http://www.youtube.com/watch?v=ACX8bseE6Ew
ive installed firmware V1.7.1.2 which appears when you scroll through the front panel.
Floppy cable is as it was ,red line on right hand side of drive ( viewed from front)
I have reformatted the sd card in FAT 32 and loaded HXCSDFE.CFG 8KB AND SP1200_OS12_SND_SP1200FD.HFE onto the card
nothing else . HFE file from https://hxc2001.com/floppy/forum/viewtopic.php?f=14&t=714
It all powers up when i insert sd card the display shows "Reading FAT...-" no noises thats all that happens
As i scroll through settings are
interface CFG :from HFE file
bitrate : from HFE file
track step: from HFE file
drive B : OFF
step sound : from CFG file
sound volume : from CFG file
standby: from CFG file
ive already had a couple of tips from 12bitski outside the forum and would be greatful if anyone can help me get it working
thanks
Re: sp1200 help required
SDCard compatibility issue... Will be solved in the next firmware version.
Have you another SDCArd brand/model to try ?
sp12000
Post by sp12000 »
yes i ve got one other card to use , does everything else seem ok jumpers , files on card and settings?
sp12000
Post by sp12000 »
thanks jeff , i formatted the other card ,loaded the files on and it all works fine now.
sp12000 wrote:thanks jeff , i formatted the other card ,loaded the files on and it all works fine now.
Just to know : can you tell me what is the brand / model of the non-working sdcard ?
