Problem with OLED and Gotek
Re: Problem with OLED and Gotek
dougal wrote: Sat Dec 02, 2017 5:12 pm
Jeff wrote: Sat Dec 02, 2017 4:18 pm I have fixed some issues + change the oled detection. Let me know if this one is working.
https://hxc2001.com/vrac/HxCUSBFE.UPD
OLED Init Delay has to be set to 3s and it works
Out of the box no oled display unless I set the init delay
Ok fine ! For the moment i will let it as is.
dougal
Post by dougal »
Hi I noticed some issues
The OLED does not always come on after the Amiga has been off for a while and I have to switch off/on again 1-3 or so for it to work [Since the latest update you gave me]
Also, sometimes I get a NO USB STICK error - It does not do it often and it does it even for example I was loading Relokick or Workbench and it gave an error (disk error on the Amiga) and then no usb stick and I had to remove the stick and re-insert it. The connections are all perfect and did not have this problem before. Its nothing major but best I mention it
dougal wrote: Sun Dec 03, 2017 9:09 am Hi I noticed some issues
Ok will add a 4s seconds delay but this cold boot issue + the usb stick issue sound to be a power supply issue.
Have a look to the 2 latest post from this thread : https://hxc2001.com/floppy/forum/viewtopi ... =33&t=3239
This sound similar...
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 10:15 am Ok will add a 4s seconds delay but this cold boot issue + the usb stick issue sound to be a power supply issue.
My set-up was recently changed but I don't think it would affect it
It is an A500 Plus with Kickstart 2.04 and 2MB Chip memory (1024K on board + 1024K ram expansion)
The Gotek is inside an old external floppy drive replacing the FDD
I am using inside the Amiga a DF0 selector to make external floppy drive DF0
The PSU is original heavy type Amiga 500 PSU
The USB drive is a SanDisk 16GB
Same question as the other thread : Have you another power supply to test ?
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 10:37 am Same question as the other thread : Have you another power supply to test ?
Maybe. I will check later on in my garage where I keep my spare Amiga stuff.
Would checking the power supply with a multi meter help ?
[Note] The power supply is the same one I use for my A1200 which has hard drive (not compact flash) + blizzard 68030 accelerator card and it seems to handle itself well on that one.
Try this one :
https://hxc2001.com/vrac/HxCUSBFE2.UPD
And let me know if you still have these issues.
(4s and 5s delay added).
(v3.1.0.2a)
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 10:48 am Try this one :
(v3.1.0.2a)
Thanks but still the same with regards the oled. It does not always work right away on a cold start.
dougal wrote: Sun Dec 03, 2017 4:12 pm
(v3.1.0.2a)
Have you set the delay to 5s ?
And about the other issue ?
Another attempt :
(v3.1.0.3a)
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 5:59 pm Have you set the delay to 5s ?
Yes I did. I also tried another power brick but same thing.
The other issue does not happen often. In the hour or so I used the Amiga it did not do it.
I will try the latest file soon and get back to you.
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 6:05 pm Another attempt :
(v3.1.0.3a)
[EDIT] Sorry it still sometimes does not bring up the OLED when switched on. I will check the oled delay settings and try some more.
[EDIT2[ It did the No USB Stick error again - Remove usb and re-insert and its fine
So far it is working good. I did not even have to set the oled timer thing and its working.
I will keep testing as I have not tested long enough and will keep you posted
dougal
Post by dougal »
dougal wrote: Sun Dec 03, 2017 6:51 pm
(v3.1.0.3a)
[EDIT3] Seems most of the time when I switch it on the OLED works but sometimes it won't. OLED INIT DELAY @ 5s
Thanks for the tests. I suspect that these screens have not the the right pull-up resistors and/or a bad reset circuit. Maybe that this screen is designed to work under 5V ?. I need to have it to really solve the issue...
dougal
Post by dougal »
Jeff wrote: Sun Dec 03, 2017 11:45 pm Thanks for the tests. I suspect that these screens have not the the right pull-up resistors and/or a bad reset circuit. Maybe that this screen is designed to work under 5V ?. I need to have it to really solve the issue...
Seems like now it’s working 80-90% of the time when switched on from off. I will keep testing everything for the next few days and keep you updated.
When the other screen arrives I will compare them and test it. At that point I could send you this screen.
