Re: Firmware updates for the STM32/Gotek HxC floppy emulators !
9 July 2019 : Firmware STM32 USB HxCFloppyEmulator v3.3.7.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Default 7 segments screen standby / powerup can changed on the custom firmware page : https://hxc2001.com/custom_fw/
HXCFEUSB_HFE_beta_firmware.zip
Custom HxC firmware
13 July 2019 : Firmware STM32 USB HxCFloppyEmulator v3.3.7.4a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- You can hide HXCSDFE.CFG, AUTOBOOT.HFE and /mount/emptyfat.img files on the stick now.
Custom HxC firmware
24 July 2019 : Firmware STM32 USB HxCFloppyEmulator v3.3.8.2a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- USB stick browser : Faster/smoother files/folders browsing.
- USB stick folder Auto mount : Faster files copy/image generation.
Custom HxC firmware
7 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.3.8.14a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Faster disk-change state head-step clear and mask ready during the diskchange delay. (Fix Yamaha Clavinova diskchange issue)
Custom HxC firmware
9 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.3.8.15a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Fix 3.3.8.14a PC Floppy interface mode regression.
Custom HxC firmware
11 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.0.0a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Work in progress : QuickDisk emulation support added !
A new build variant is now available to emulate QuickDisk drive !
The Gotek floppy port to the QuickDisk interface is :
-- Shugart pin -- -- QuickDisk Machine--
Pin 2 (/DC) -> /MS (/MediaSense)
Pin 10 (/DS0) -> Connect it to GND/VSS
Pin 16 (/MotorOn) -> /MO
Pin 20 (/Step) -> /RS (/Reset)
Pin 22 (/WriteData) -> /WD (/WriteData)
Pin 24 (/WriteGate) -> WG (WriteGate)
Pin 28 (/WriteProtect) -> WP (WriteProtect)
Pin 30 (/ReadData) -> RD (ReadData)
Pin 34 (/Ready) -> /RY (/Ready)
Pins 4,6,8,12,14,18,26 and 32 can be left unconnected on the Gotek.
Odd pins Gotek pins (1,3,5,7,...,33) should be connected to the GND/VSS.
The jumper must be set to "MO".
A Blank QuickDisk floppy disk can be found in the firmware archive in the /QuickDisk folder.
Custom HxC firmware
13 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.1.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : Write support fixed (DMA descriptors fixed).
Custom HxC firmware
14 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.1.2a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : More important write support fixes !
Custom HxC firmware
15 August 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.1.4a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : More Fixes again ! Blank.qd image : Ready window increased from 5s to 5.5s.
Custom HxC firmware
1 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.2.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : Various write enhancement for Roland machines support (Roland S-10,S-220,...)
- OSD : Keys/Rotary wake-up behavior changed/enhanced.
Custom HxC firmware
3 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.4.6a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : Fixes/Timing improvements. Data masked outside the read window.
- OSD : Keys/Rotary regression fixed.
Custom HxC firmware
5 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.5.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
New direct raw format support :
- BAS Embroidery machines format (*.IMG,*.DSK) (System Family menu : "BAS" / 7 digits display menu entry -> 01A )
Custom HxC firmware
8 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.6.4a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- New custom firmware page option : Ignore/disable /SIDE1 input.
- QuickDisk support : Fix the /Reset input behavior :
The /Reset input doesn't stop the motor if this /Motor-on is asserted but always clear the ready signal.
Custom HxC firmware
14 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.7.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- QuickDisk support : Fix MB87013 based QD machines support (Akai S700/x7000, Roland...) -> Now support the special MB87013 sync method.
Custom HxC firmware
18 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.7.11a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Better ready timings.
- Support Roland /RY signal behavior. (Firmware QuickDisk\HxCFEUSB_V3_4_7_11a_Roland_QuickDisk.UPD)
Custom HxC firmware
