Problem with OLED and Gotek
Re: Problem with OLED and Gotek
Btw can you try this ? : switch off the Amiga, keep the Amiga in reset, switch on the Amiga, wait ~5 seconds, remove the gotek reset strap.
Is the screen working in this case ?
dougal
Post by dougal »
Keep the Amiga or Gotek in reset ?
dougal wrote: Thu Nov 30, 2017 7:28 am Keep the Amiga or Gotek in reset ?
The gotek.
dougal
Post by dougal »
Jeff wrote: Thu Nov 30, 2017 7:20 am Btw can you try this ? : switch off the Amiga, keep the Amiga in reset, switch on the Amiga, wait ~5 seconds, remove the gotek reset strap.
Yes/No
Amiga off - Hold Reset on Gotek - Switch on Amiga - in less than 5 sec let go of reset
The OLED is working but the Gotek makes sounds from buzzer like its updating for a few seconds (maybe 15 seconds) and then it works as normal.
dougal wrote: Thu Nov 30, 2017 7:01 pm
Yes/No
Interesting. If you reduce the reset time (~1 second) is the oled screen still working ?
dougal
Post by dougal »
Jeff wrote: Thu Nov 30, 2017 10:23 pm Interesting. If you reduce the reset time (~1 second) is the oled screen still working ?
Ok, I set the setting on the OLED to 750ms and then Exit
Then Amiga off
Hold Reset on the Gotek
Switch on Amiga while keep holding Reset (Gotek)
Give about 3 seconds and let go
OLED on
ADF boots up normal
Is this firmware working with the OLED ?
https://hxc2001.com/vrac/HxCUSBFE2.UPD
dougal
Post by dougal »
Jeff wrote: Sat Dec 02, 2017 1:20 am Is this firmware working with the OLED ?
2.5s Delay working!! Perfect :D :D
Thank you so much for your time and patience with this issue :)
dougal wrote: Sat Dec 02, 2017 9:09 am
Ok fine. :) But i don't like at all the patch to make it work. I recommend you to use the other oled screen.
I have to get one of these "diymore" screen to figure out what is the source of this issue...
btw i will rename/change the option in the next releases. Let me know if i broke the fix later.
dougal
Post by dougal »
I think there is a bug
It sometimes says NO USB FOUND and then Reading FAT and again NO USB
Then I tried remove USB and insert again and there is garbage on the OLED and it is making sounds like trying to update
I switched off Amiga and trying again now. So far its working again
dougal
Post by dougal »
So far its all good again
dougal wrote: Sat Dec 02, 2017 9:44 am So far its all good again
Yes. Take care with the power supply connector on the gotek : if not connected correctly you can get such "funny" behaviour...
This device and the usb stick are sensitive to any power supply voltage variation made by a bad contact or something else.
I have fixed some issues + change the oled detection. Let me know if this one is working.
https://hxc2001.com/vrac/HxCUSBFE.UPD
dougal
Post by dougal »
Jeff wrote: Sat Dec 02, 2017 4:18 pm I have fixed some issues + change the oled detection. Let me know if this one is working.
OLED Init Delay has to be set to 3s and it works
Out of the box no oled display unless I set the init delay
