SP1200 with Gotek HxC
Re: SP1200 with Gotek HxC
A blank file is needed to make proper tests.
SynthGeek
Post by SynthGeek »
Jeff wrote: Thu Oct 19, 2017 2:06 pm A blank file is needed to make proper tests.
How do I go about making that happen? The disks I'm using were pulled from the hxc site.
SynthGeek wrote: Fri Oct 20, 2017 1:59 am
Here is a blank image :
https://hxc2001.com/download/floppy_driv ... /Blank.hfe
kerussm
Post by kerussm »
Yeah so same issue here. It won’t save no matter what.
Here are files for proper testing. Hopefully it helps.
They are on your email too
You can send files for test over email to make things quicker.
Thanks. I need to fix the firmware but i don't have the sp1200 to test it.
Are you ok to tests some of my alphas, possibly with a lot of failure and disappointment ? :wink:
kerussm
Post by kerussm »
Jeff wrote: Sat Nov 11, 2017 12:44 pm Thanks. I need to fix the firmware but i don't have the sp1200 to test it.
Sure, if that will help me and others then why not. We will have to arrange a time for this sessions as I have rotated shifts at work. Best for me would be test couple of files at same time and if you let me know before there is something coming. Let me know on email as there I have notifications thru my phone.
kerussm wrote: Sat Nov 11, 2017 12:50 pm
ok ! i will send you a first one in some minutes.
Btw have you a serial adapter usb<>serial adapter ? This is to get the output debugs which may help to understand what is wrong.
After inspection of your hfe it appears that the written data are valid (valid crc). this means that the data are correctly captured, which is a good news.
so the issue shouldn't too hard to fix.
kerussm
Post by kerussm »
Don’t have usb-serial but how much it would cost in UK to buy?
If you got any spare, I can give you my address to have it posted and once we’re done I would send it back to you.
Also have send invitation for my google drive on your email as created a folder to exchange files. Have a look.
If you could email me instead I will respond quicker as here on forum got no notifications whatsoever
kerussm wrote: Sat Nov 11, 2017 2:47 pm Also have send invitation for my google drive on your email as created a folder to exchange files. Have a look.
Please avoid to attach or publish my emails to any of these website/services.
i will send you the firmwares to your email registered here.
kerussm
Post by kerussm »
sure thing. Didn't meant to publish anything without your permission
sent !
Jeff wrote: Sat Nov 11, 2017 3:45 pm Update procedure : https://hxc2001.com/docs/gotek-floppy-e ... pdate.html
SP1200 write support fix (data write, not format !):
Thanks to kerussm for the tests ! :D
