Akai S950
Re: Akai S950
Jeff wrote:Any wattage is ok.
Yes this is this place.
aaking76
Re: Akai S950
Post by aaking76 »
Cant get High Density images to work...
I am attaching the images, I have no problem with DD,I have backed up many and they all work, but I have not gotten one HD image to work...
The .AKAI file is here, I made it with omniflop, using the s950 hd setting
https://dl.dropbox.com/u/18509785/CRUMAR1.AKAI
and here is the HFE made the same as I have been making dd only changing to hd setting.
https://dl.dropbox.com/u/18509785/CRUMAR.hfe
I am really happy so far, but really need to get this High Density thing worked out...
Any help will be greatly appreciated, I also just did a blog post about this adventure...
http://bitvoltage.com/mod-your-akai-s95 ... rd-reader/
Re: Akai S950
The image looks good. Did you have applied the resistor mod ?
Firmware version used ?
aaking76
Re: Akai S950
Post by aaking76 »
Yes I have the resistor mod, and thanks for chaecking my images...
It ended up being a setting in the emulator itself that I must have changed during initial trouble shooting...
in the main menu, I had chosen akai dd images, I changed that to from hfe file, and now it
WORKS!!!
YAY, thanks again....
Re: Akai S950
aaking76 wrote:Yes I have the resistor mod, and thanks for chaecking my images...
WORKS!!!
Yes common mistake. I will make a "trouble shooting" page to help to solve this kind of misconfiguration.
Feliks
Re: Akai S950
Post by Feliks »
Hi everyone,
I've been trying to avoid posting unnecessarily and had hoped to solve my problem myself but I've been re-reading this thread over and over for the past 3 days and I'm still having issues with HxC rev F in my S950.
So far, not a single version of the HxC Config file has worked, every possible version I try to load says "BAD FILE!" and whenever I try to load or save anything from the S950 to a floppy image on the disk it shows "Disk is unprepared, you must FORMAT it.........."
My HxC drive has the R12 resistor mod (Installed by Lotharek) as well as the correct jumper setting (ID0A is the only switch in "on" position) and the HxC also has the latest firmware (1.7.2.0) installed.
PLEASE HELP! :?
Re: Akai S950
And with this ? :
Have you formatted your SD in FAT32 ?
EDIT : about the "BAD FILE" - this is normal since you need to load an HFE file, not a CFG file.
Feliks
Re: Akai S950
Post by Feliks »
My SD card is a Sandisk 4gb SDHC, Formatted in FAT32 on OSX, Is that likely to cause any problems?
I've tried the S950 disk Images from that Zip file with no success.
What should I try next?
Re: Akai S950
Feliks wrote:My SD card is a Sandisk 4gb SDHC, Formatted in FAT32 on OSX, Is that likely to cause any problems?
When you select an HFE file, what can you read on the LCD ?
"RA ....." at the second line ?
EDIT : If you always see a "RA" at the the second line, with all hxc LED always on and without any other behavior when you try to read the disk, this means that the floppy cable is not connected to the right way. In this case, reconnect it to the other way (the colored wire to the opposite).
Feliks
Re: Akai S950
Post by Feliks »
When I try to access a .HFE file it displays "RA" followed by Track data counts and stuff.
Does that mean I should reverse the floppy cable?
Also, it appears that the screen contrast on my HxC drive is turned up as the characters have become hard to see when looking at them straight on. I have to look at the screen from a slightly upward angle to make out the writing. Is this a fault?
Re: Akai S950
Feliks wrote:When I try to access a .HFE file it displays "RA" followed by Track data counts and stuff.
S:1 at the end ? If yes -> YES.
Feliks wrote: Also, it appears that the screen contrast on my HxC drive is turned up as the characters have become hard to see when looking at them straight on. I have to look at the screen from a slightly upward angle to make out the writing. Is this a fault?
a picture please ?
And a picture of the floppy power supply connector !
Feliks
Re: Akai S950
Post by Feliks »
Ok......
It did say S:1, I tried to open my sampler to change the floppy cable back but a screw on my S950 threaded so I can't get into my S950 at all.
Also, I can't get a decent pic, my only camera is a crappy cellphone camera and I don't have anywhere to upload the pic to.
Re: Akai S950
Feliks wrote:Ok......
You have no choice : you must reconnect the floppy cable correctly !
Feliks
Re: Akai S950
Post by Feliks »
I know, Just need to go buy some screw extractors now before I can do anything else.
Re: Akai S950
Buy some screw extractors ? Seriously ?
