Akai S950
Re: Akai S950
COBOLT wrote:Yes i have,
i formated card with vista.
The display show reading fat when card is empty or when cfg. file is on.
Can you check that you are using a 5V power supply source ?
COBOLT
Re: Akai S950
Post by COBOLT »
yes it is 5V
Re: Akai S950
yes it is 5V
In this case try to find another SDCard brand/model and update the firmware with this one :
https://hxc2001.com/floppy_drive_emulat ... 6_4_4A.UPD
COBOLT
Re: Akai S950
Post by COBOLT »
yes it is 5V
ok i upgrade the os but if put the cfg. file and touch middle buton its show bad file
many thanks for your reply jeff
Re: Akai S950
COBOLT wrote: ok i upgrade the os but if put the cfg. file and touch middle buton its show bad file
Of course. You need HFE files image on your SDCard.
Some ready to use HFE files :
COBOLT
Re: Akai S950
Post by COBOLT »
Thanks its working !
COBOLT
Re: Akai S950
Post by COBOLT »
I have a problem that I can not solve. it is an import samples into my akai. I also tried akai prepared image from S900blogspot but writes unformatted. if I try to format the card so nothing happens is still unformatted. What is the correct procedure?
But if I use a file from Jandoe file is uploaded. Sorry for my bad English.
Re: Akai S950
COBOLT wrote:Hi Jeff,
Did you solve your problem ?
COBOLT
Re: Akai S950
Post by COBOLT »
NO :(
Re: Akai S950
Can you give a link to the S900blogspot images ?
950er
Re: Akai S950
Post by 950er »
Hi there!
I have a Akai S950 with the ib105 board... bought a DMA cable and a cased ICD Advantage Plus ST hostadapter connected to a Conner harddisk, Syquest 270mb drive and a centronics adapter... but it won't work.
I connected two different external 100mb zip-drives and one 250mb zip-drive to the centronics adapter... won't work.
I heard that you have to wait for like a half minute until you switch on the s950 after turning on the external components... won't work.
I wanted to connect the recently ordered Rev F cardreader to the icd adapter (instead of the syquest drive) to back up my floppies... and after that's done build it inside the s950
What am I doing wrong???
Now I want to check if the icd board is okay. Does anyone know which of the 50 pins is for the power???
Any clues, any solutions...
Please help me out here!
950er
Re: Akai S950
Post by 950er »
One more thing:
Do I need to load the icd software on my s950???
If so... how do I manage that???
Thanks in advance,
950er
Re: Akai S950
950er wrote:One more thing:
Thanks in advance,
950er
What is the "icd software" ? (in fact the question is : what is an icd board ?)
COBOLT
Re: Akai S950
Post by COBOLT »
950er
Re: Akai S950
Post by 950er »
Hi Jeff
thanks for the quick response!
The icd software is tu run the icd board on the atari but I guess I can't install it the usual way in my 950?!
The icd advantage plus st is an "interface" made for atari st's... http://www.icd.com/atari/
The 950 has a 19pin Atari DMA port (ib105) which is connected to the icd board to "normally" use hd's and other external hardware like the floppy emulator.
