New HxC Floppy Emulator software for Windows and Mac OS X !
Re: New HxC Floppy Emulator software for Windows and Mac OS X !
Hi!
Thank you for the great software. I'd like to ask you, if this is possible, to add a checkbox (three state), which is corresponding to pin 2 on the cable. Logic 1, logic 0 and ignored. This will help me, and probably not only me, to switch 5.25 floppies RPM on demand.
Have a nice day!
Have a nice day!
What is the latest version for Mac OS X? When I download from the link the Mac version is 2.0.6.0, with a creation date of December 30, 2016. Is this correct?
thx!
Not it is not. the Mac version was updated too.
Then would you please provide a link to the updated Mac OS X version? When I click on the link from your post of January 21 2018 and unzip the file, the Mac OS X version of the app still says 2.0.6.0
thank you
thank you
Just checked, i have downloaded and tested the archive on Mac. The defaults links are definitively pointing to the the 2.0.8.0. Your browser cache or proxy is probably the problem.marzzz wrote: Sun Mar 11, 2018 7:46 pm Then would you please provide a link to the updated Mac OS X version? When I click on the link from your post of January 21 2018 and unzip the file, the Mac OS X version of the app still says 2.0.6.0
thank you
Purging the cache fixed the problem, I think?Jeff wrote: Mon Mar 12, 2018 1:04 amJust checked, i have downloaded and tested the archive on Mac. The defaults links are definitively pointing to the the 2.0.8.0. Your browser cache or proxy is probably the problem.
Downloaded the file, and when I click on and open the app it says across the top of the app's window:
HxCFloppyEmulator v2.1.8.0.
When I go to "About HxCFloppyEmulator" up on the main menu, it opens a window that says:
Version 2.0.6.0 (59)
In The Finder, if I select the app icon with "Command-I" it says:
Version: 2.0.6.0
...hence my confusion. I am in the process of installing the drive, so as long as it works that's fine.
Here's a compiled version of HXC_floppy_emulator version 2.1.6.0 for ubuntu.
Just need to install libfltk to get it working.
Jeff may add it to the website front page for better access.
NOTE:the whole file is too large to be included here (it misses the libhxcfe.so)
- hxc-linux.zip
- (158.33 KiB) Downloaded 2303 times
New HxC Software version ! : HxCFloppyEmulator 2.1.20.1
https://hxc2001.com/download/floppy_dri ... r_soft.zip
22 December 2018 : HxCFloppyEmulator 2.1.20.1
General : Faster/better file images identification and loader.
General : Many loaders now use the new generic raw file loader.
General : Lots of code improvements.
Internal tracks generator : Now support "weak" sectors.
HFEv3 writer : Remove any possible parasitic opcodes coming from the stream.
New Loader : NEC PC98/PC88 FDI.
CPCDSK loader/writer : Now support the SAMDisk method for DSK with weak bits.
Roland DD XML : Fix tracks skew.
New XML format : ABB disks formats.
New XML format : Automatix RAIL DD disk format.
New XML format : COMX disks formats.
New XML format : DEC RX55 format.
New XML format : Didaktik Spectrum disk format.
New XML format : Dynacord HD disks formats.
New XML format : Gravograph ISIS 640KB disk format.
New XML format : Memotech disks formats.
New XML format : Oerlikon Balzers disks formats.
New XML format : OpusDiscovery disk format.
New XML format : Oric Jasmin disk format.
New XML format : OS9 DD disks formats.
New XML format : PUMA arm robot disks formats.
New XML format : Tatung Einstein disks formats.
New XML format : Timex FDD3000 formats.
New XML format : TRS80 disk format.
New XML format : Unitel Videotex format.
New file image support : SAB Diskette Utility / *.SDU floppy image.
SCP Loader/Writer : Fix single sided SCP file export.
New writer : Dragon VDK format.
Change urls to point to the main hxc2001 domain + switch to https.
Kingstener
I have just extract the last version from the repo and compiled - this can not read td0 files ("read file error")
Edit: Windows version too...
Jeff_HxC2001
ok looking at the issue.Kingstener wrote: Mon Dec 24, 2018 1:40 pm Hi,
Jeff_HxC2001
Fixed on the repository. fixed DLL incoming for Windows.Jeff_HxC2001 wrote: Mon Dec 24, 2018 8:01 pmok looking at the issue.Kingstener wrote: Mon Dec 24, 2018 1:40 pm Hi,
Kingstener
The Mac verrsion doesn't launch. I copied the app into my Applications dir, and double-c-lick on it, but nothing noticeable happens. No icon appears in the Dock either.
Do I need to install it some other way, or do the cli/framework parts have to be installed somewhere?
This is on Mac OS X Mojave 10.14.2 (18C54).
EDIT: I think this is my problem, I misunderstood. I thought this was a file manager for the USB used in a Gotek running HXC firmware, but it seems it is for the actual HxC unit which I do not have, which is probabably why it is not launching.
Sorry!
Sorry!
No this is not the reason. It should start. btw i have just updated the archive.n9yty wrote: Tue Jan 01, 2019 9:27 pm The Mac verrsion doesn't launch. I copied the app into my Applications dir, and double-c-lick on it, but nothing noticeable happens. No icon appears in the Dock either.
Sorry!
Retry with the new one. If it still doesn't start try this :
https://support.apple.com/kb/PH25088?locale=en_US
The binary isn't signed, so this is probably the issue...
New HxC Software version ! : HxCFloppyEmulator 2.1.21.1
01 January 2019 : HxCFloppyEmulator 2.1.21.1
Dos disk browser : Amiga HD (1760KB) disk creation support.
Dos disk browser : Amiga HD (1760KB) disk support fixed.
TeleDisk loader fixed : Bad CRC checking fixed.
