Converting GHK files using import raw image
Re: Converting GHK files using import raw image
cixelsyd wrote:
cixelsyd wrote:Hi Jeff,
still no good. I'm getting the same "Bad Device ID" from the Ensoniq.
Let me know if you want copies of the files.
Regards
James
Yes send me the HFE+GHK file.
Done
mhh nothing received here ?
cixelsyd
Post by cixelsyd »
they were over 2 meg so the mail server refused it. I've resent them as separate files
cixelsyd wrote:they were over 2 meg so the mail server refused it. I've resent them as separate files
Nothing received.
anyway a new software :
Version (v1.6.11.14a):
Regards
James
your floppy image have a missing sector at each track.
to open the GKH file image don't use the "Load Raw image" anymore.
GKH isn't a raw file image (there are a file header).
Just do a "load" or a drag & drop of the GKH file on the main window.
then export to hfe.
that's all.
2 GKH HFE files :
https://hxc2001.com/floppy_drive_emulat ... ac/GKH.zip
The last software:
cixelsyd
Post by cixelsyd »
Hey Jeff,
Thanks for the assistance. It is indeed working when I use the "import" button.
Great product and great support
Thanks again
Nephilim
Post by Nephilim »
Hello Jeff
Convert .EDA ==> EDA.hfe = OK with ENsoniq Asr10 ( all is OK sound download on track is OK )
Convert .GKH ==> GKH.hfe = KO with ENsoniq Asr10 ( sound is on the screen but download = "disk software error " or " Disk Not Formated " or " disk drive not ready " )
Convert .EDE ==> EDE.hfe = KO with ENsoniq Asr10 ( sound is on the screen but download = "disk software error " or " Disk Not Formated " )
Do you have a solution ?
Nephilim wrote:Hello Jeff
Yes : Change/force the interface mode for the Asr10 (Should be IBM PC DD or HD).
Nephilim
Post by Nephilim »
Hello Jeff
Where i can do that ?
Can you send me a config file to Ensoniq ASR10 ??
MatthewleBlom
Post by MatthewleBlom »
Hello all,
I haven't managed to load some GKH files either.
Tried what was written here... (drag files into HXC software and export it a HFE).
But I think some thing in de config file aren't ok yet.
I tried IBM formats.
What could I do wrong here?
I even swapped a Gotek/HXC by a Lotharek.
At this moment I have a Lotharek in mij ASR10(rack).
