YAMAHA TX16W
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
Hello everybody,
I am new to this forum and need some advice:
anyone succeeded loading a set of two discs using the hxc-emulator?
If so, please tell me how to do it.
Best regards
Lovejoy
Re: YAMAHA TX16W
Do you have the last firmware ?
Anyway don't forget to set the interface mode to "generic shugart".
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
Thanks for your reply. I have to check this. which one is the latest?
Re: YAMAHA TX16W
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
checked latest firmware an "generic shugart"-setting but still no success. :( I also put all image files into the root directory - just in case...
any further avice?
Regards
Re: YAMAHA TX16W
What is your jumper setting ?
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
experienced the same error when loading soundsets consisting of two disks from floppy. So it seems to be more a matter of importing 2-disk soundsets into the TX16W. Anyway, the problem is still not solved. :/
Best regards
Lovejoy
Re: YAMAHA TX16W
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
Oh, sorry, I haven´t answered yourquestion yet. Jumper-settings are: Drive A, ID0, reverse floppy cable.
Regards
Lovejoy
Re: YAMAHA TX16W
Have you tried the ready-to-use images ? :
Do you have changed the interface mode with the menu on the HxC ?
Lovejoy
Re: YAMAHA TX16W
Post by Lovejoy »
goos news: changed the interface mode on the hxc an now it works great!!!
Thank you a lot for your advice :))
regards
Lovejoy
springreverb
Re: YAMAHA TX16W
Post by springreverb »
Hi Ohmen52,
Have you tried putting and aiff from a mac or pc onto the sd card and then reading it from the tx16w?
This im very interested in as it would be great!
And I cant get a floppy drive to work on my mac anymore :) , well not to save data anyhow
Robert
Ohmen52
Re: YAMAHA TX16W
Post by Ohmen52 »
regarding your problem the following link will maybe of interest to you. I'll try it myself to find out the correct solution for the HxC:
http://soniccharge.com/forum/index.php? ... ppy-image/
Regards
Re: YAMAHA TX16W
Why you don't use the HxC DosDiskBrowser software for this :?:
https://hxc2001.com/download/floppy_driv ... rowser.zip
springreverb
Re: YAMAHA TX16W
Do you know of a USB floppy drive that can also write to floppydisks that works on Mac OSX 10.9?
